map doesn't show
1465
6
10-03-2016 02:03 PM
ahmedalgosaibig
I'm trying to run the sample from this site Get started with MapView - Create a 2D map | ArcGIS API for JavaScript 4.1 , but the map doesn't show?
If you you have any idea, plz share it
Thank you
RobertScheitlin__GISP
Ahmed,
  What do you mean
You copied the html code to a html file on your web server and the map is not showing?
Are there any errors in your browsers web console?
ahmedalgosaibig
I copied and pasted in html file. I don't have web server
Ahmed,
   If you do not have a web server (like IIS on your machine) then you can not run html files from your machine. Running files with a url like this will not work:
file:///C:/JS_Workspace/EXPORT_FeatureTable.html
ahmedalgosaibig
I'll try it
DevonBise
New Contributor III
Have you tried running the sample in different browsers?  Sometimes cleaning out the cookies can kickstart a hung website.  I would advise cleaning out your cookies and switching to a new browser temporarily if that doesn't work.  Let me know if this works and if not we can go from there.  Cheers!
ahmedalgosaibig
I tried it, but nothing the map doesn't show up
