Switch basemap WKID to 3440
1242
10-04-2016 01:52 AM
Abdul_Razakck
I am a web application developer new to ESRI javascript API. My company wants to use ESRI Map service to plot their data in Map. I have achieved all my requirement with ESRI javascript API except setting custom SpatialReference.  because my company is using a specific system: PSD93 so I want to set a custom WKID: 3440 with the basemap:"topo" to complete the requirement.
Thanks in advance
please see my below code:
var map, toolbar, symbol, geomTask, linesymbol, customExtentAndSR, sr, webutil; require(["esri/map","esri/toolbars/draw","esri/dijit/BasemapGallery","esri/graphic","esri/symbols/SimpleMarkerSymbol","esri/symbols/SimpleLineSymbol","esri/symbols/SimpleFillSymbol","esri/symbols/CartographicLineSymbol","esri/symbols/PictureMarkerSymbol","dojo/parser""dijit/registry","dijit/layout/BorderContainer""dijit/layout/ContentPane","dijit/form/Button""dijit/WidgetSet""dojo/domReady!""esri/SpatialReference""esri/geometry/Extent"], function ( Map, Draw, BasemapGallery, Graphic, SimpleMarkerSymbol, SimpleLineSymbol, SimpleFillSymbol, CartographicLineSymbol, PictureMarkerSymbol, parser, registry, SpatialReference, webMercatorUtils, Extent ) {     parser.parse();
var
 bounds = new esri.geometry.Extent({             "xmin": 180203.8880,             "ymin": 1859530.0038,             "xmax": 809128.4715,             "ymax": 2923231.7211,             "spatialReference": { "wkid": 3440 }         });
Snippet
var renewPoint = new esri.geometry.Point(defaultLong, defaultLat, new esri.SpatialReference({ "wkid": 3440 }));
map = new Map("map", {             basemap: "topo",             center: [defaultLong, defaultLat], zoom: defaultZoom, force3DTransforms: true        });
thejuskambi
Occasional Contributor III
All the basemaps hosted on Arcgis Online are Cached services. That means you cannot use it with a spatial reference other than it is defined.
If you would like to show the map in a custom spatial reference than you would have to create your own map service for basemap.
thejuskambi
