AnsweredAssumed Answered
Webapp builder Infowindow not showing content.
Question asked by brett1989 on Oct 3, 2016
Latest reply on Oct 4, 2016 by rscheitlin
Hi Guys
I have a custom basic widget to calculate the lengths of a polygon. The calculations seems to be fine but I cannott get the content to display in the infowindow. The setTitle seems to work fine but as soon as I try to set the content it shows nothing... any ideas?
my code:
define(['dojo/_base/declare', 'jimu/BaseWidget','esri/tasks/IdentifyTask',
  'esri/tasks/IdentifyParameters',"esri/tasks/GeometryService", "esri/InfoTemplate"],
function(declare, BaseWidget, IdentifyTask, IdentifyParameters, GeometryService, InfoTemplate) {
  //To create a widget, you need to derive from BaseWidget.
  return declare([BaseWidget], {
    // Custom widget code goes here
    baseClass: 'Dimension',
    // this property is set by the framework when widget is loaded.
    // name: 'Dimension',
    // add additional properties here
    //methods to communication with app container:
    postCreate: function() {
      this.inherited(arguments);
      console.log('Dimension::postCreate');
      mainMap = this.map;
      var firstGraphic = null;
      console.log(mainMap.infoWindow);
      //user clicked point
        mainMap.on("click", function (evt) {
            //get site name clicked with id
             //initialize identity task
            identifyTask = new IdentifyTask("*/arcgis/rest/services/Merafong/Merafong_base/MapServer");
            identifyParams = new IdentifyParameters();
            identifyParams.tolerance = 3;
            identifyParams.returnGeometry = true;
            identifyParams.layerIds = [43];
            identifyParams.layerOption = IdentifyParameters.LAYER_OPTION_VISIBLE;
            identifyParams.width = mainMap.width;
            identifyParams.height = mainMap.height;
            identifyParams.geometry = evt.mapPoint;
            identifyParams.mapExtent = mainMap.extent;
            var results = new Array();
            var currentClick = evt.mapPoint;
            //run identify task results
            identifyTask.execute(identifyParams, function (idResults) {
             console.log(mainMap);
             len = idResults[0].feature.geometry.rings[0].length;
            //calculate lengths between each vertex
             for (var i = 0; i < len; i++) {
                        var p1 = idResults[0].feature.geometry.rings[0][i]
                        if (i == len - 1){
                            var p2 = idResults[0].feature.geometry.rings[0][0]
                        else {
                            var p2 = idResults[0].feature.geometry.rings[0][i + 1]
                        var polyline = {
                            "paths": [[p1, p2]],
                            "spatialReference":{"wkid":idResults[0].feature.geometry.spatialReference.wkid}
                        polyline = new esri.geometry.Polyline(polyline);
                        polyline = esri.geometry.webMercatorToGeographic(polyline);
                        results[i] = esri.geometry.geodesicLengths([polyline],esri.Units.METERS);
                        console.log(results[i]);
            mainMap.infoWindow.setTitle("Dimension Results");
            var content = "<table border='1'><th><td>Erf Dimensions (Meter) </td></th>";
            for (var i = 0; i < results.length - 1; i++){
                content += "<tr><td>" + results[i] + "</td></tr>";
            content += "</table>";
            mainMap.infoWindow.setContent("My infoWindow Content");
            mainMap.infoWindow.show(mainMap.toScreen(currentClick),             mainMap.getInfoWindowAnchor(mainMap.toScreen(currentClick)));
Outcomes
