I have two polygons, one stacked inside another. How do I enable the vertices to edit the shape? In the larger polygon I can just click again on the shape and the vertices show. For the smaller it opens the attributes dialogue box for editing.
Solved! Go to Solution.
Turning off the larger polygons layer allows for the second click to access the vertices. If the polygons are in the same feature class they can be selected as normal.
