AnsweredAssumed Answered
Feature service misallingment in ArcGIS Online. Alligns properly in ArcMap and Collector in offline mode.
Question asked by DeyalAdmin on Sep 22, 2016
Latest reply on Sep 26, 2016 by KGerrow-esristaff
Hi all,
I have an issue with feature layers in ArcGIS Online. I am adding an ArcGIS server web service witch creates a feature layer and then i add the feature layer in a web map. There are 11 layers in the feature layer. When i try to open the webmap i get a message that a layer is not responding
This is a water network map. As you can see the pipes are misalligned and some pipes are missing.
When i use the Collector app and download the map for offline use, they get alligned properly and there is nothing missing.
On another instance if i use a map image Layer everything shows up ok.
The spatial reference is Greek Grid (2100)
I am using ArcMap 10.4, Arcgis Server 10.4, the service details are as following (for one of the 11 layers)
Layer: ΔΙΚΛΕΙΔΕΣ ΠΕΖΟΔΡΟΜΙΟΥ (ID: 0)
View In:   ArcGIS Online map viewer
Name: ΔΙΚΛΕΙΔΕΣ ΠΕΖΟΔΡΟΜΙΟΥ
Display Field: FACILITYID
Type: Feature Layer
Geometry Type: esriGeometryPoint
Description: This dataset contains a collection of features that represent the water distribution network in a community.
Definition Expression: N/A
Copyright Text:
Default Visibility: true
MaxRecordCount: 5000
Supported Query Formats: JSON, AMF, geoJSON
Min Scale: 2000
Max Scale: 0
Supports Advanced Queries: true
Supports Statistics: true
Use Standardized Queries: true
Supports ValidateSQL: true
Supports Calculate: false
Extent:
      XMin: 350329.08951833844
      YMin: 4373931.874201424
      XMax: 373356.6671507545
      YMax: 4398354.849961676
      Spatial Reference: 2100  (2100)
Drawing Info:Renderer:Simple Renderer:
Symbol:Picture SymbolLabel:
Description:Transparency: 0
Labeling Info:Label Placement: esriServerPointLabelPlacementAboveRight
Label Expression: [code]
Use Coded Values: true
Symbol:Color: [0, 0, 0, 255]
Background Color: [233, 255, 190, 255]
Outline Color: [0, 0, 0, 255]
Vertical Alignment: bottom
Horizontal Alignment: left
Right to Left: false
Angle: 0
XOffset: 0
YOffset: 0
Font Family: Arial
Font Style: normal
Font Weight: normal
Font Decoration: none
Min. Scale: 500.0
Max. Scale: 0.0
Advanced Query Capabilities:
      Supports OrderBy: true
      Supports Distinct: true
      Supports Pagination: true
      Supports TrueCurve: false
HasZ: false
HasM: false
Has Attachments: false
HTML Popup Type: esriServerHTMLPopupTypeAsHTMLText
Type ID Field:
Fields:
  • too many to display
Templates:
    Drawing Tool: esriFeatureEditToolPoint
Capabilities: Create,Query,Update,Sync,Delete,Uploads,Editing
Sync Can Return Changes: true
Is Data Versioned: true
Supports Rollback On Failure: false
Supports ApplyEdits With Global Ids: false
Supported Operations:   Query   Apply Edits   Add Features   Update Features   Delete Features   Validate SQL   Generate Renderer   Return Updates
Does anyone have a clue?
Thank you.
Outcomes
