AnsweredAssumed Answered
Problem using Features from Survey123 in Collector
Question asked by johan.ekenstedt_sveaskog on Sep 22, 2016
Latest reply on Sep 23, 2016 by johan.ekenstedt_sveaskog
I have made a simple form in Survey123 and it works good. When I add the resulting feature-layer in a Webmap it looks good. But when I use that Feature Layer in Collector (iOS 10 and Collector 10.4.0) I run into real problem. Sometimes the webmap doesn´t show up in Collector, sometimes it crashes when I try to open the webmap.
I tried to create a form in the Webapplication (Survey123) and the resulting feature-layer  is possible to use online in Collector. It isn´t possible to use the result in an offline map - I couldn´t change the settings of the Feature Layer in AGOL.
Is there any known issues when using features from Survey123 in Collector?
Take a look at the following webmap and feature and try to use them in collector:
http://sveaskog.maps.arcgis.com/home/item.html?id=58e61ab3704d4399a60335b0be936bdc
http://sveaskog.maps.arcgis.com/home/item.html?id=c73d79b2cc0740d3adb7ecc39df29412
Best Regards / Johan Ekenstedt
Outcomes
