get coordinates of the polygon
1559
09-20-2016 01:39 PM
GeorgeCastell
I am new to using ArcGIS API, I need your help. someone can help me, I'm doing a project where the user draws a polygon and need to capture the coordinates of the polygon drawn.
I am leading this example
https://developers.arcgis.com/javascript/3/jssamples/util_label_point.html
Thank you...
EvelynHernandez
Occasional Contributor III
I think here u can get them:
function addToMap(evtObj) {
      map.graphics.clear();
      var geometry = evtObj.geometry;
      // add the drawn graphic to the map
      var symbol = new SimpleFillSymbol(
        SimpleFillSymbol.STYLE_SOLID,
        new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new Color([0, 0, 0]), 2),
        new Color([0, 0, 255, 0.5]));
      var graphic = new Graphic(geometry, symbol);
 // u will have the geometry itself so u can get the coords for the polygon drawn but u need to use a for loop to get them all.
       console.log(geometry.rings);  //<-- array of coords.
      map.graphics.add(graphic);
      // simplify polygon so it can be used in the get label points request
      geometryService.simplify([geometry], getLabelPoints);
EvelynHernandez
GeorgeCastell
Thank you very much, I'll try.
