Selected symbol not changing color
1583
09-19-2016 11:24 AM
KarstenRank
Occasional Contributor III
Hi there,
I want to change the selected symbols depending on the geometry of the feature layer. My code looks like that:
switch (geoType) {
 case "esriGeometryPoint":
 selectionSymbol = new SimpleMarkerSymbol(SimpleMarkerSymbol.STYLE_CIRCLE, 20);
 break;
 case "esriGeometryPolygon":
layer.selectionSymbol = new SimpleFillSymbol(SimpleFillSymbol.STYLE_SOLID,
 new SimpleLineSymbol(SimpleLineSymbol.STYLE_DASHDOT,
 new Color([255, 120, 0]), 2), new Color([255, 255, 0, 0.5]));
 break;
 case "esriGeometryPolyline":
layer.selectionSymbol = new CartographicLineSymbol(CartographicLineSymbol.STYLE_SOLID, new Color([255,255,255,1]), 2);
layer.setSelectionSymbol(selectionSymbol);‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
The marker symbol for point geometry changes, the others get transparent?
Where is the error?
Thank you
Karsten
KenBuja
MVP Esteemed Contributor
For the point case, you use
selectionSymbol = new ...‍‍
but the polyline and polygon cases, you use
You have to use
for these cases since "layer.selectionSymbol" is not the same as "selectionSymbol". Otherwise, you're creating a new property on the "layer" variable instead of setting a new value for the "selectionSymbol" variable. Since "selectionSymbol" is not being set in those two cases, a null value will be set in the setSelectionSymbol method at the end of your code fragment.
KenBuja
You have to use
KarstenRank
Hello Ken,
thank you for the help. Now it works!
