AnsweredAssumed Answered
Sync Geodatabase Issues
Question asked by mfjd80 on Sep 14, 2016
Latest reply on Nov 4, 2016 by mfjd80
Greetings!
Working on my first Qt app but have not been able to get past the first basic steps. For the app I have a feature service with two layers, layer 0 is for device location (points) and layer 1 is for service areas (polygons). I want to sync service areas from the server to the device (SyncDirectionDownload) and sync device location from the device to the server (SyncDirectionUpload ). I am expecting upon initial sync to the geodatabase, the service areas should be downloaded to the device's geodatabase, but this is not the case. I have tried a few different ways but either no features are downloaded or there are errors.  Any input on what I am doing wrong or if I need to go about this a different way is greatly appreciated!
Josh
Each step is connected to separate buttons. Here is the output for each button:
getServiceButton:
(onFeatureServiceInfoStatusChanged): qml: capabilities: Create,Delete,Query,Sync,Update,Uploads,Editing
(onFeatureServiceInfoStatusChanged): qml: max record count: 1000
(onFeatureServiceInfoStatusChanged): qml: sync enabled?: true
(onFeatureServiceInfoStatusChanged): qml: server version: 10.41
generateButton:
(onClicked): qml: Generating geodatabase...
(onGenerateStatusChanged): qml: Generate geodatabase in progress...
(onGeodatabaseSyncStatusInfoChanged): qml: Sync status: 0
(onGenerateStatusChanged): qml: Generate geodatabase complete.
(onGenerateStatusChanged): qml: path: data/localdata.geodatabase
(onGenerateStatusChanged): qml: sync enabled: true
(onGenerateStatusChanged): qml: sync model: 1
(onGenerateStatusChanged): qml: valid: true
registerButton:   not sure if this is functioning properly
(onClicked): qml: Registering geodatabase...
syncButton:   will error
(onClicked): qml: Syncing geodatabase...
(onSyncStatusChanged): qml: Sync geodatabase in progress...
(onSyncStatusChanged): qml: Error: Invalid or missing input parameters. code= 400 Replica with this GUID does not exist on the server
(onSyncStatusChanged): qml: Error: Protocol "" is unknown code= 301 Protocol "" is unknown
(onSyncStatusChanged): qml: Error: Sync failed. Unable to import changes to server. code= -1
Info from the feature server:
Sync Capabilities:
Supports Registering Existing Data: true
Supports Sync Direction Control: true
Supports PerLayer Sync: true
Supports PerReplica Sync: false
Supports RollbackOnFailure : false
Supports Async: true
Supports ApplyEdits With Global Ids: true
Child Resources: Info Uploads Replicas
Supported Operations: Query Apply Edits Create Replica Synchronize Replica Unregister Replica
The code snippet below is what I believe is the closest to what I need (my apologies on the formatting from copy/paste), but it will error when trying to sync.
import QtQuick 2.3
import QtQuick.Controls 1.2
import QtPositioning 5.2
import QtQuick.Dialogs 1.2
import QtQuick.Layouts 1.1
import QtQuick.Controls.Styles 1.2
import ArcGIS.Runtime 10.26
ApplicationWindow {
width: 800
height: 600
title: "my cool app"
property string featureServerUrl: // ** url left out on purpose**
property string gdbPath: "data/localdata.geodatabase"
Envelope {
xMin: -100
xMax: -85
yMin: 40
yMax: 50
SpatialReference{
wkid: 4326
ServiceInfoTask {
url: featureServerUrl
onFeatureServiceInfoStatusChanged: {
if (featureServiceInfoStatus === Enums.FeatureServiceInfoStatusReady) {
console.log("Fetch feature server info ready...")
else if (featureServiceInfoStatus === Enums.FeatureServiceInfoStatusInProgress) {
console.log("Fetch feature server info in progress...")
else if (featureServiceInfoStatus === Enums.FeatureServiceInfoStatusCompleted) {
Enums.FeatureServiceInfoStatusErrored
var featureServiceInfo = featureServiceInfoTask.featureServiceInfo
console.log("capabilities:", featureServiceInfo.capabilities)
console.log("max record count:",
featureServiceInfo.maximumRecordCount)
console.log("sync enabled?:", featureServiceInfo.isSyncEnabled)
console.log("server version:", featureServiceInfo.version)
else if (featureServiceInfoStatus === Enums.FeatureServiceInfoStatusErrored) {
console.log("Fetch feature server info ERRORED...")
GenerateGeodatabaseParameters {
extent: env
layerIds: [0, 1]
syncModel: Enums.SyncModelLayer
outSpatialReference: sr
LayerSyncInfo {
layerId: 0
syncDirection: Enums.SyncDirectionUpload
LayerSyncInfo {
layerId: 1
syncDirection: Enums.SyncDirectionDownload
SyncGeodatabaseParameters {
layerSyncInfos: [layerSyncInfoPoints, layerSyncInfoPolygons]
Geodatabase {
path: gdbPath
GeodatabaseSyncStatusInfo {
GeodatabaseSyncTask {
onGenerateStatusChanged: {
// generate in progress
if (generateStatus === Enums.GenerateStatusInProgress) {
console.log("Generate geodatabase in progress...")
// generate complete
else if (generateStatus === Enums.GenerateStatusCompleted) {
console.log("Generate geodatabase complete.")
console.log("path: " + gdb.path)
console.log("sync enabled: " + gdb.isSyncEnabled)
console.log("sync model: " + gdb.syncModel)
console.log("valid: " + gdb.valid)
// generate error
else if (generateStatus === GeodatabaseSyncTask.GenerateError) {
console.log("Error: " + generateGeodatabaseError.message
+ " Code= " + generateGeodatabaseError.code.toString(
) + " " + generateGeodatabaseError.details)
onSyncStatusChanged: {
// sync is ready
if (syncStatus === Enums.SyncStatusReady) {
console.log('Sync geodatabase ready...')
// sync in progress
if (syncStatus === Enums.SyncStatusInProgress) {
console.log('Sync geodatabase in progress...')
// sync complete
else if (syncStatus === Enums.SyncStatusCompleted) {
console.log("Sync Geodatabase Complete.")
var gdbtables = gdb.geodatabaseFeatureTables
for (var i in gdbtables) {
var geodatabaseFeatureTable = gdbtables[i]
console.log(geodatabaseFeatureTable.featureServiceLayerName)
console.log(geodatabaseFeatureTable.features.length)
// sync error
else if (syncStatus === Enums.SyncStatusErrored) {
console.log("Error: " + syncGeodatabaseError.message + " code= "
+ syncGeodatabaseError.code.toString(
) + " " + syncGeodatabaseError.details)
onGeodatabaseSyncStatusInfoChanged: {
// uploading status
if (geodatabaseSyncStatusInfo.status === Enums.GeodatabaseStatusUploadingDelta) {
var deltaProgress = geodatabaseSyncStatusInfo.deltaUploadProgress / 1000
var deltaSize = geodatabaseSyncStatusInfo.deltaSize / 1000
console.log(geodatabaseSyncStatusInfo.statusString + " " + String(
deltaProgress) + " of " + String(
deltaSize) + " KBs...")
else{
console.log("Sync status: " + geodatabaseSyncStatusInfo.status)
Column {
width: 800
height: 600
anchors.leftMargin: 0
anchors.topMargin: 0
anchors {
left: parent.left
top: parent.top
margins: 20
spacing: 7
Button {
text: "Get Service Info"
enabled: true
onClicked: {
console.log("Getting service info...")
featureServiceInfoTask.fetchFeatureServiceInfo()
console.log(featureServiceInfoTask)
Button {
text: "Generate Database"
enabled: true
onClicked: {
generateGeodatabaseParameters.initialize(featureServiceInfoTask.featureServiceInfo)
generateGeodatabaseParameters.extent = env
generateGeodatabaseParameters.returnAttachments = false
console.log("Generating geodatabase...")
geodatabaseSyncTask.generateGeodatabase(generateGeodatabaseParameters, gdbPath)
Button {
text: "Register Database"
enabled: true
onClicked: {
// register geodatabase
console.log("Registering geodatabase...")
geodatabaseSyncTask.registerGeodatabase(gdb)
Button {
text: "Sync Database"
enabled: true
onClicked: {
console.log("Syncing geodatabase...")
geodatabaseSyncTask.syncGeodatabase(
syncGeodatabaseParameters, gdb)
Outcomes
