iterate through sub-layers
2103
6
09-13-2016 08:34 AM
BrianFoley1
I have a dynamicmapservicelayer (dynaLayer1) that has three layers. Each layer then has at least 2 sub-layers beneath it.
dynaLayer1
----> Layer 1
--------> Sub-Layer 1
--------> Sub-Layer 2
----> Layer 2
----> Layer 3
I am using the following code to get the layers.  How can I get to the sub-layers (Sub-Layer 1 & 2) below that ?
Thanks.
dojo.connect(dynaLayer1, "onLoad", function () {
    var infos = dynaLayer1.layerInfos;
        for (var i = 0; i <= infos.length - 1; i++) {
                var layerId = infos.id;
                var layerName = infos.name;
                var layerVisible = infos.defaultVisibility;
                alert("layerId : " + layerId + ".....layerName : " + layerName + ".....visible : " + layerVisible);
Drew
Occasional Contributor III
Here is a sample i made using some public data
Edit fiddle - JSFiddle
Drew
The layerInfos class has a "subLayerIds" property.
That will give you the Id's you need.
LayerInfo | API Reference | ArcGIS API for JavaScript 3.17
BrianFoley1
Andrew,
When I run the code, the subLayerIds is null. Also, how can I get the name of the sub-layer ?
Brian
Drew
If "subLayerIds" is null then something else is wrong. Try publishing your service again and look at the REST endpoint to ensure they exist.
To get the name you just need to get the LayerInfo of the item..
var layerName = infos[mySubLayerId].name;
RobertScheitlin__GISP
The subLayerIds will always be null if it is not a parent layer(meaning that the layer is not a grouped layer). You should check if the parentLayerId is not null before worrying about subLayerIds.
BrianFoley1
The parentId is -1.
This is my code :
var initialExtent = new Extent
                 xmin: -8119646.38042271,
                 ymin: 4986891.42830988,
                 xmax: -8102329.13378822,
                 ymax: 4999699.14992532,
                  "spatialReference": { "wkid": 102100 }
 map = new Map("map", {
            extent: initialExtent,
            smartNavigation: false,
            slider: false,
            zoom: 14
baseLayer = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer");
map.addLayer(baseLayer);
dynaLayer1 = new esri.layers.ArcGISDynamicMapServiceLayer ( "https://xxxxxxxxxx/ArcGIS/rest/services/xxxxx/Contaminated_Areas",
            id: "Contaminated Areas", opacity: 0.8
dynaLayer1.setVisibleLayers([0, 1, 2]);
map.addLayers([dynaLayer1]);
              //alert("layerId : " + layerId + ".....layerName : " + layerName + ".....visible : " + layerVisible);
Drew
