Populate rows using Update Cursor based on a list of repeating values
898
09-09-2016 08:47 AM
ZacharyHart
Occasional Contributor III
I've been searching high and low for this (Stackoverflow/exchange, etc, Geonet...). Here it goes. I have a table with a number of records. I have a field called 'Rotation' I would like to populate with a repeating set of values [0,90,180,270]. So imagine the following:
PT_IDROTATION
3180
4270
50
690
7180
8270
90
I've tried to simplify my question as much as possible, but its literally as simple as that. Most of the searches return information related to deleting duplicate/repeated records & values.
JoshuaBixby
MVP Esteemed Contributor
itertools.cycle()
Haven't tested but something like:
>>> from itertools import cycle
>>> rot = cycle((0,90,180,270))
>>> with arcpy.da.UpdateCursor(in_table,["PT_ID","ROTATION"]) as cur:
...     for row in cur:
...         row[1] = next(rot)
...         cur.updateRow(row)
JoshuaBixby
itertools.cycle()
...     for row in cur:
ZacharyHart
Joshua, this is exactly what I needed, thanks!!!
DarrenWiens2
MVP Honored Contributor
Go with Joshua's answer, I was just curious to see how hard this would be in Field Calculator (as long as your IDs are reliable):
VB Script (but could do the same in Python): (([PT_ID]-1)*90)-( Int(([PT_ID]/4)-0.25) *360)
