How to change the web map at run-time
1256
09-06-2016 11:03 PM
StephenLead
Regular Contributor III
When creating a new Web AppBuilder application, you need to choose the Web Map which will be used in the application.
Is it possible to change this at run-time, ie while using the application?
RobertScheitlin__GISP
Stephen,
   Sure there is a widget for that:
https://community.esri.com/docs/DOC-7630
Stephen,
Vara_PrasadM_S
Occasional Contributor II
Hi Robert,
Is it possible to do the same thing using custom code if we know webmap id?
Thanks in advance!
With Regards,
Vara Prasad.
Vara,
   I have not tried but I would say yes. Just look at Davids code in the widget.
