Graphics crossing International Date Line
1165
09-02-2016 11:38 AM
ChristinaKochan1
I have my map set to WrapAround = true, but I can't get Graphics to cross the IDL. If I have a polyline whose points are [5,175] and [5,-175], instead of crossing the IDL it gets stretched across the whole Earth. I can set the second point to [5, 185] and it will display correctly, but then other parts of my application see that 185 as an invalid longitude. Is there anything I can set on the map or on the graphic to get it to do what I want it to do without having to convert back and forth between valid and invalid longitude values?
AnttiKajanus1
Occasional Contributor III
You should use NormalizeCentralMeridian utility when WrapAround is enabled.
