AnsweredAssumed Answered
New Map Instance not loading base layer
Question asked by donnaghmcmahon181 on Sep 1, 2016
Hi Guys,
RE:(JavaScriptAPI)
I have a question to do with the ".removeAllLayers();" function. I am trying to remove all the layers on the current map except for the base layer (the map itself), however when i do "mainMap = new esriMap" it doesnt seem to work.
function BuildMap(layerMap) {
    esriUrlUtils.addProxyRule({
      urlPrefix: 1sttUrlPrefix, proxyUrl: urlProxy, });
   esriUrlUtils.addProxyRule({ urlPrefix: 2ndUrlPrefix, proxyUrl: urlProxy, });
esriConfig.defaults.io.corsDetection = false;
//Check if the map exists, if so - remove the existing layers //If not - just create a new map
if (mainMap == null) {
mainMap = new esriMap("map", { basemap: "satellite",
//Focus on the first location from the list (or the only location)
center: [modelLocations[0].Longitude, modelLocations[0].Latitude],
zoom: 6 });
else {
//Remove existing layers
removeLayers();
//Now, add new layers to the map
addLayers(layerMap);
function removeLayers() {
                     //Initial code
//Remove all the existing layers apart from the base layer (the map itself)
//var mapLayersCount = mainMap.layerIds.length;
//if (mapLayersCount > 4) {
// for (var i = 0; i <= 3; i++) {
// mainMap.removeLayer(mainMap.getLayer(mainMap.layerIds[1]));
//} else if (mapLayersCount > 3) {
// for (var i = 0; i <= 2; i++) {
//} else if (mapLayersCount > 2) {
// for (var i = 0; i <= 1; i++) { /
//} else {
tried several combinations to clear the map div and map instance.
mainMap.removeAllLayers();
mainMap.destroy();
mainMap = undefined;
$("#map").empty();
zoom: 6 }); } }
Outcomes
