Geoenrichment with ArcGIS Online Proxy
2361
10
09-01-2016 01:21 PM
JoshuaTanner2
New Contributor III
Has anybody had luck using the Geoenrichment with a proxy setup at developers.arcgis.com?  `.../rest/services/World/GeoenrichmentServer` works fine, but trying to access '.../rest/services/World/GeoenrichmentServer/Geoenrichment/Enrich' gives me a 401 error (you do not have permissions).  Suggestions?  My domain is white listed and I can access the base REST endpoint fine, I just can't get to the additional routes that I need to actually use it.
DanielStauning
Hi Joshua,
This is a bug that was introduced with an update to the Geoenrichment service last night. We are working to patch this as soon as we can, I'll update this thread as soon as it's fixed.
-Daniel
DanielStauning
Hi Joshua,
-Daniel
JoshuaTanner2
New Contributor III
Thanks Daniel.  I'll keep an eye our for your update.
DanielStauning
Hi Joshua,
A fix for this issue was applied last night, please let us know if you're still having any trouble with this work flow. Thanks for your patience in this matter.
Daniel
SimoneGadenz1
Daniel Stauning
I am experiencing the same issue with the URL: http://geoenrich.arcgis.com/arcgis/rest/services/World/GeoenrichmentServer/GetDataCollections/execut...
The page that gives the error is here:
Geoanalyst
and the error reports "You are currently signed in as: 'beeagodev'. You do not have access to this resource: http://geoenrich.arcgis.com/arcgis/rest/services/World/GeoenrichmentServer/GetDataCollections/execut...
It used to work with the ArcGISOnline DEMO subscription I used in August to develop a DEMO, but it stopped when I started using the developer user couple of days ago.
Should I change some configuration moving from the demo environment to the developer one or it is a bug similar the one you described above?
Thanks for any feedback.
Simone
DanielStauning
Hi Simone,
Are you still running into this issue? There was a problem with backward compatibility for the GetDataCollections method after a recent update to Geoenrichment. However, it was patched last night. Let me know if we can help.
Dan
SimoneGadenz1
Thanks Daniel Staining‌, the previous problem is solved. But now I have another issue, for any enrichment I run i got the "Error: Geoenrichment service returned empty response(...)" in file Geoenrichment.js:12
Looking at the network when it runs the analysis id calls two pages, the geoenrichment and the reverse geocoding. The second one works fine, the geoenrichment call is:
  1. [{"areaType":"DriveTimeBuffer","bufferUnits":"esriMiles","bufferRadii":[2],"returnGeometry":true,"comparisonLevels":[{"layer":"Admin3"},{"layer":"Admin2"},{"layer":"Admin1"}],"geometry":{"x":1261390.5194081098,"y":5360108.141509999,"spatialReference":{"wkid":102100,"latestWkid":3857}}}]
  2. useData:
    {"sourceCountry":"IT"}
  3. analysisVariables:
    ["KeyGlobalFacts.*"]
  4. outSR:
  5. forStorage:
    false
  6. f:
    json
  7. token:
    oV9ShBhDPLaUkuSiXunAr0MSQNvNZ3imq1AdTFICUblWBo22urfdxJ8Z4md8kU48mVXnYgahBhAlpMCPpD6moQJJEwzuPLmEsYa1eGu_UiyQfrdS4xqKu_CezWY6O_CeajUcTgO-QyCkSGjBd4i9sYxtE3_o1wC2_xqeYUZIk_4.
with this response:
{"results":[{"paramName":"GeoEnrichmentResult","dataType":"GeoEnrichmentResult","value":{"version":"2.0","FeatureSet":[]}}],"messages":[{"description":"Study area at [0] was ignored. Failed to build network service area. Internal error.","id":46975,"type":"unknown"}]}
It looks like the DriveTimeBuffer is the problem.
Best.
DanielStauning
Simone,
It seems to work for me when I use those parameters in an enrich request; you'll need to add your token to the example below.
https://geoenrich.arcgis.com/arcgis/rest/services/World/geoenrichmentserver/Geoenrichment/Enrich?stu...
 "features" : [ {
 "attributes" : {
 "ID" : "0",
 "OBJECTID" : 1,
 "sourceCountry" : "IT",
 "areaType" : "DriveTimeBuffer",
 "bufferUnits" : "esriMiles",
 "bufferUnitsAlias" : "Miles",
 "bufferRadii" : 2,
 "aggregationMethod" : "CentroidsInPolygon:IT.Municipalities",
 "HasData" : 1,
 "TOTPOP" : 53058,
 "TOTHH" : 24900,
 "AVGHHSZ" : 2.13,
 "TOTMALES" : 24192,
 "TOTFEMALES" : 28866
 "geometry" : {
 "rings" : [ [ [ 1260187.7721999995, 5362511.405299999 ], [ 1260237.8808999993, 5362408.0748 ], [ 1260362.7280000001, 5362408.0748 ], [ 1260412.8366999999, 5362270.886200003 ], [ 1260637.9012999982, 5362339.188199997 ], [ 1260737.6941, 5362545.849100001 ], [ 1260837.9114999995, 5362579.7092999965 ], [ 1261037.9217999987, 5362270.886200003 ], [ 1261288.0406999998, 5362029.789499998 ], [ 1261437.9422999993, 5362133.115800001 ], [ 1261612.8980999999, 5362133.115800001 ], [ 1261688.0610999987, 5361995.931500003 ], [ 1261987.8641999997, 5362029.789499998 ], [ 1262012.9186000004, 5362029.789499998 ], [ 1262112.7113999985, 5361995.931500003 ], [ 1262162.8200999983, 5361892.6065 ], [ 1262137.7657000013, 5361789.282899998 ], [ 1262312.7215000018, 5361686.544 ], [ 1262412.9389999993, 5361514.342200004 ], [ 1262412.9389999993, 5361239.409900002 ], [ 1262337.7758999988, 5361171.115800001 ], [ 1262237.9831000008, 5361205.5546 ], [ 1262362.8302000016, 5360827.318400003 ], [ 1262512.7316999994, 5360896.193599999 ], [ 1262638.0036000013, 5360827.318400003 ], [ 1262962.8608999997, 5360964.4855 ], [ 1262638.0036000013, 5361342.727399997 ], [ 1262638.0036000013, 5361377.1668 ], [ 1262638.0036000013, 5361514.342200004 ], [ 1262362.8302000016, 5361823.723999999 ], [ 1262387.8845999986, 5361961.489600003 ], [ 1262463.047699999, 5362029.789499998 ], [ 1262587.8949000016, 5361961.489600003 ], [ 1262937.806499999, 5361548.782300003 ], [ 1263638.0546999983, 5361067.800099999 ], [ 1263687.7388000004, 5361067.800099999 ], [ 1263638.0546999983, 5361239.409900002 ], [ 1263737.8475000001, 5361342.727399997 ], [ 1263737.8475000001, 5361377.1668 ], [ 1263838.0650000013, 5361342.727399997 ], [ 1263937.8575999998, 5361446.0462 ], [ 1264038.075100001, 5361308.288099997 ], [ 1264013.0207999982, 5361171.115800001 ], [ 1264112.8136, 5361067.800099999 ], [ 1264287.7694000006, 5361205.5546 ], [ 1264437.6708999984, 5361033.3618 ], [ 1264462.7252999991, 5360930.631300002 ], [ 1264362.932500001, 5360792.880800001 ], [ 1264213.0309999995, 5360792.880800001 ], [ 1264162.9222999997, 5360724.006399997 ], [ 1263987.9664000012, 5360792.880800001 ], [ 1263813.010499999, 5360758.443599999 ], [ 1264162.9222999997, 5360346.373400003 ], [ 1264312.8238000013, 5360414.661399998 ], [ 1264337.8781000003, 5360414.661399998 ], [ 1264413.0412999988, 5360449.097400002 ], [ 1264537.8883999996, 5360346.373400003 ], [ 1264537.8883999996, 5360174.196400002 ], [ 1264387.9868, 5360071.475599997 ], [ 1264613.0513999984, 5359968.171999998 ], [ 1264662.7355000004, 5359865.453299999 ], [ 1264637.6810999997, 5359762.1521999985 ], [ 1264562.9426999986, 5359693.285400003 ], [ 1264413.0412999988, 5359693.285400003 ], [ 1264362.932500001, 5359762.1521999985 ], [ 1264238.0852999985, 5359693.285400003 ], [ 1264137.867899999, 5359831.019400001 ], [ 1263987.9664000012, 5359831.019400001 ], [ 1263737.8475000001, 5359590.569700003 ], [ 1263562.8916000016, 5359556.1369 ], [ 1263613.0003000014, 5359383.9745000005 ], [ 1263838.0650000013, 5359349.542499997 ], [ 1263838.0650000013, 5359315.694200002 ], [ 1263987.9664000012, 5359246.830600001 ], [ 1263987.9664000012, 5359074.674099997 ], [ 1263813.010499999, 5359006.395900004 ], [ 1263638.0546999983, 5358834.243799999 ], [ 1263537.8372999988, 5358971.965300001 ], [ 1263562.8916000016, 5359074.674099997 ], [ 1263312.7727000006, 5359452.8391999975 ], [ 1263112.7624999993, 5359281.262400001 ], [ 1263112.7624999993, 5359074.674099997 ], [ 1263012.9697000012, 5358937.5348000005 ], [ 1262912.7522, 5359006.395900004 ], [ 1262887.6977999993, 5359177.967600003 ], [ 1262612.9492000006, 5359452.8391999975 ], [ 1262587.8949000016, 5359452.8391999975 ], [ 1262488.1020999998, 5359521.7042 ], [ 1262387.8845999986, 5359383.9745000005 ], [ 1262362.8302000016, 5358903.1044000015 ], [ 1262737.7963999994, 5358525.545299999 ], [ 1263187.9255000018, 5358387.8303999975 ], [ 1263337.8269999996, 5358216.2733 ], [ 1263287.7182999998, 5358078.563000001 ], [ 1263187.9255000018, 5358044.135799997 ], [ 1263038.0240000002, 5357838.158500001 ], [ 1262912.7522, 5357907.011600003 ], [ 1262887.6977999993, 5358009.708700001 ], [ 1262937.806499999, 5358112.990500003 ], [ 1262937.806499999, 5358147.4179000035 ], [ 1262638.0036000013, 5358250.701099999 ], [ 1262362.8302000016, 5358559.390699998 ], [ 1262237.9831000008, 5358525.545299999 ], [ 1262137.7657000013, 5358353.402000003 ], [ 1262288.0918999985, 5358181.8455 ], [ 1262362.8302000016, 5357872.585000001 ], [ 1262088.0815999992, 5357357.368299998 ], [ 1261987.8641999997, 5357426.217699997 ], [ 1261937.7553999983, 5357563.3347999975 ], [ 1261937.7553999983, 5357838.158500001 ], [ 1262037.9728999995, 5357975.8653 ], [ 1262037.9728999995, 5358009.708700001 ], [ 1261912.7010999992, 5358422.258900002 ], [ 1262088.0815999992, 5358697.108099997 ], [ 1262037.9728999995, 5359006.395900004 ], [ 1262162.8200999983, 5359212.3989999965 ], [ 1262187.874400001, 5359899.3037 ], [ 1262012.9186000004, 5360105.9103000015 ], [ 1261912.7010999992, 5360037.040799998 ], [ 1262112.7113999985, 5359831.019400001 ], [ 1262162.8200999983, 5359693.285400003 ], [ 1262088.0815999992, 5359556.1369 ], [ 1261962.809799999, 5359521.7042 ], [ 1261962.809799999, 5359556.1369 ], [ 1261912.7010999992, 5359556.1369 ], [ 1261762.7996000014, 5359831.019400001 ], [ 1261663.0067999996, 5359590.569700003 ], [ 1261712.6909000017, 5359315.694200002 ], [ 1261587.8436999992, 5359143.5363000035 ], [ 1261612.8980999999, 5358971.965300001 ], [ 1261437.9422999993, 5358662.678400002 ], [ 1261437.9422999993, 5358387.8303999975 ], [ 1261362.7791000009, 5358250.701099999 ], [ 1261537.7349999994, 5357975.8653 ], [ 1261663.0067999996, 5357426.217699997 ], [ 1261787.8539000005, 5357357.368299998 ], [ 1261787.8539000005, 5357322.943599999 ], [ 1261888.0714000016, 5357185.8301 ], [ 1261987.8641999997, 5357185.8301 ], [ 1262088.0815999992, 5357322.943599999 ], [ 1262162.8200999983, 5357288.519100003 ], [ 1262212.9287, 5357185.8301 ], [ 1262187.874400001, 5357082.558600001 ], [ 1262263.0373999998, 5356979.288400002 ], [ 1262237.9831000008, 5356876.6027000025 ], [ 1262162.8200999983, 5356807.757299997 ], [ 1262012.9186000004, 5356876.6027000025 ], [ 1261888.0714000016, 5356773.3347999975 ], [ 1261737.7452000007, 5357013.7117 ], [ 1261513.1053000018, 5357116.982299998 ], [ 1261437.9422999993, 5357288.519100003 ], [ 1261137.7146000005, 5357528.909500003 ], [ 1260962.7586000003, 5357391.7929000035 ], [ 1260962.7586000003, 5357357.368299998 ], [ 1260837.9114999995, 5357185.8301 ], [ 1260762.7485000007, 5357219.670699999 ], [ 1260713.0643999986, 5357322.943599999 ], [ 1260737.6941, 5357426.217699997 ], [ 1260612.8469999991, 5357563.3347999975 ], [ 1260637.9012999982, 5357701.0374 ], [ 1260187.7721999995, 5358112.990500003 ], [ 1260162.7177999988, 5358216.2733 ], [ 1260212.8264999986, 5358318.9738000035 ], [ 1260012.816300001, 5358387.8303999975 ], [ 1259862.9147000015, 5358559.390699998 ], [ 1259787.751699999, 5358491.1162 ], [ 1259513.0031000003, 5358559.390699998 ], [ 1259412.7855999991, 5358697.108099997 ], [ 1259412.7855999991, 5358731.537699997 ], [ 1259287.9384000003, 5358868.674099997 ], [ 1259338.0472000018, 5359109.1052 ], [ 1259187.7210999988, 5359281.262400001 ], [ 1259138.0368999988, 5359246.830600001 ], [ 1259062.8739, 5359315.694200002 ], [ 1258963.0810999982, 5359658.8522000015 ], [ 1259087.9283000007, 5359796.585699998 ], [ 1259187.7210999988, 5359658.8522000015 ], [ 1259487.9486999996, 5359624.419100001 ], [ 1259687.958900001, 5359487.271600001 ], [ 1259762.6974, 5359796.585699998 ], [ 1259612.7958999984, 5360071.475599997 ], [ 1259612.7958999984, 5360277.502300002 ], [ 1259612.7958999984, 5360311.937799998 ], [ 1259662.9045999981, 5360380.809100002 ], [ 1259637.8502000012, 5360621.279299997 ], [ 1259687.958900001, 5360861.755900003 ], [ 1259738.0676000006, 5360964.4855 ], [ 1259837.8603999987, 5360998.923699997 ], [ 1259887.9692000002, 5361136.677100003 ], [ 1260037.8707000017, 5361239.409900002 ], [ 1259962.7074999996, 5361617.6630000025 ], [ 1260162.7177999988, 5361858.1652000025 ], [ 1260162.7177999988, 5361961.489600003 ], [ 1259938.0779, 5361961.489600003 ], [ 1259862.9147000015, 5362029.789499998 ], [ 1259837.8603999987, 5362167.558200002 ], [ 1259713.0132, 5362236.443400003 ], [ 1259713.0132, 5362442.518200003 ], [ 1259862.9147000015, 5362614.153300002 ], [ 1259887.9692000002, 5362614.153300002 ], [ 1259962.7074999996, 5362614.153300002 ], [ 1259962.7074999996, 5362648.597400002 ], [ 1260187.7721999995, 5362511.405299999 ] ] ]
 "attributes" : {
 "ID" : "0",
 "OBJECTID" : 2,
 "StdGeographyLevel" : "IT.Regions",
 "StdGeographyName" : "Toscana",
 "StdGeographyID" : "09",
 "aggregationMethod" : "Query:IT.Regions",
 "HasData" : 1,
 "TOTPOP" : 3710157,
 "TOTHH" : 1580024,
 "AVGHHSZ" : 2.35,
 "TOTMALES" : 1772655,
 "TOTFEMALES" : 1937502
 "attributes" : {
 "ID" : "0",
 "OBJECTID" : 3,
 "StdGeographyLevel" : "IT.Postcodes1",
 "StdGeographyName" : "Firenze",
 "StdGeographyID" : "5",
 "aggregationMethod" : "Query:IT.Postcodes1",
 "HasData" : 1,
 "TOTPOP" : 3710173,
 "TOTHH" : 1580030,
 "AVGHHSZ" : 2.35,
 "TOTMALES" : 1772664,
 "TOTFEMALES" : 1937509
 "attributes" : {
 "ID" : "0",
 "OBJECTID" : 4,
 "StdGeographyLevel" : "IT.Country",
 "StdGeographyName" : "Italy",
 "StdGeographyID" : "01",
 "aggregationMethod" : "Query:IT.Country",
 "HasData" : 1,
 "TOTPOP" : 59929192,
 "TOTHH" : 24574680,
 "AVGHHSZ" : 2.44,
 "TOTMALES" : 28950567,
 "TOTFEMALES" : 30978625
 "messages" : [ ]
SimoneGadenz1
Thanks Daniel Staining‌ for reply.
I tested your URL and it does not work using a token I got with my user Simone Gadenz, both using proxy or not.
This is the reply:
{   "results" : [ {     "paramName" : "GeoEnrichmentResult",     "dataType" : "GeoEnrichmentResult",     "value" : {       "version" : "2.0",       "FeatureSet" : [ ]     }   } ],   "messages" : [ {     "description" : "Study area at [0] was ignored. Failed to build network service area. Internal error.",     "id" : 46975,     "type" : "unknown"   } ] }
Any additional test I can do?
Best
S
chakreshsahu
New Contributor III
Hi Simone,
Same issue, i was facing. Reducing DriveTimeBuffer has resolved the issue
