Is there any way to share code in the same installation?
541
08-25-2016 07:55 AM
MikkelHylden
Even though we have installed WAB Dev on a server where multiple developers can access the site (so using the same installation directory and app code directory), the apps generated by one user are not visible to other developers.  There is a link below where someone has submitted an idea to ESRI to make sharing possible, but I have yet to see an implementation in practice that works, other than transferring files around manually.  As mentioned in that thread, it is common to have multiple developers working on the same project, needing to pick up where someone else left off, or just doing some testing.
If anyone has come up with a solution, any ideas would be greatly appreciated.
https://community.esri.com/ideas/11292
RobertScheitlin__GISP
Mikkel,
   I have not seen any posts on successful use of a centralized WAB Dev shared by multiple developers. It is just not designed for that.
MikkelHylden
That’s what I was afraid of, and seems to be the consensus… Thanks though.
Mikkel
