Using dojo FilteringSelect for autocomplete functionality
2375
08-22-2016 02:59 PM
RogerF
I have a feature service published out of data from our enterprise geodatabase. I need to implement autosuggest/autocomplete functionality based on attributes of
feature class of published service. Has anyone implemented anything similar ? any pointers will be greatly appreciated.
RobertScheitlin__GISP
Roger,
  I have personally developed my own RESTful .Net web service that handles auto complete for me then I built a custom dijit "Suggest_TextBox" that connects with my webservice. There may be an easier way but for a developer like me this was the easy route.
RogerF
Thank you Robert for your quick response.
Would you mind posting some sample code on how to do that ?
Roger,
   Here is the Suggest_TextBox.js code:
define(['dojo/_base/declare',
  'dojo/_base/html',
  'dijit/form/ValidationTextBox',
  'dijit/_HasDropDown',
  'dojo/on',
  'esri/request',
  'dojo/_base/lang',
  'dojo/Deferred',
  'dijit/Menu',
  'dijit/MenuItem',
  'dojo/_base/array',
  'dijit/focus',
  'dojox/html/entities',
  'dojo/query'],
  function (declare, html, ValidationTextBox, _HasDropDown, on, esriRequest, lang,
    Deferred, Menu, MenuItem, array, focusUtil, entities, query) {
    return declare([ValidationTextBox, _HasDropDown], {
      required: false,
      trim: true,
      characters: 3,
      searchAlias: null,
      enterPressed: false,
      postCreate: function () {
        this.own(on(this, 'keyup', lang.hitch(this, '_onKeyUp')));
        this.own(on(this, 'keydown', lang.hitch(this, '_onKeyDown')));
      _onKeyDown: function (evt) {
        if(evt.key === 'Enter' && this.dropDown){
          this.enterPressed = true;
          this.closeDropDown();
        this.enterPressed = false;
        return true;
      _onKeyUp: function (evt) {
          return;
        if (this.get('value').length >= this.characters) {
          this._popup(evt.key);
      _popup: function (key) {
        var value = this.get('value');
        var def = new Deferred();
        if(key === 'ArrowDown' && this.dropDown){
          if(focusUtil.curNode){
            focusUtil.curNode.blur();
          focusUtil.focus(this.dropDown);
          return;
        if(key === 'Enter' && this.dropDown){
          return;
        def.then(lang.hitch(this, function (resp) {
          // Create our new Menu (the drop down)
          this.dropDown = new Menu({});
          array.map(resp.suggestions, lang.hitch(this, function(val){
            var item = new MenuItem({
              label: val,
              onClick: lang.hitch(this, function (evt) {
                var evtObj;
                if(evt.target.tagName === 'TR'){
                  evtObj = query('.dijitMenuItemLabel',evt.target)[0].innerHTML;
                }else{
                  evtObj = evt.target.innerHTML;
                this.attr('value', entities.decode(evtObj));
            this.dropDown.addChild(item);
          if(this.enterPressed){return;}
          this.openDropDown();
        }), lang.hitch(this, function (err) {
          console.info(err);
        var endPointUrl;
        var content;
        switch(this.searchAlias){
          case 0:
            endPointUrl = "http://mywebservice/suggest/ppins";
            content = {ppin: value,f: 'json'};
            break;
          case 1:
            endPointUrl = "http://mywebservice/suggest/parcelnumbers";
            content = {parcelnum: value,f: 'json'};
            break;
          case 2:
            endPointUrl = "http://mywebservice/suggest/ownernames";
            content = {owner: value,f: 'json'};
            break;
          case 3:
            endPointUrl = "http://mywebservice/suggest/addresses";
            content = {address: value,f: 'json'};
            break;
        esriRequest({
          url: endPointUrl,
          content: content,
          handleAs: "json",
          timeout: 10000
        },{useProxy: true, usePost: false, disableIdentityLookup: true}).then(lang.hitch(this,function(response){
          def.resolve(response);
        }), lang.hitch(this, function(err){
          def.reject(err);
and a portion of the web service that deals with suggestions:
<WebGet(UriTemplate:="/suggest/ownernames?owner={owner}", ResponseFormat:=WebMessageFormat.Json, BodyStyle:=WebMessageBodyStyle.Bare)>
        Public Function GetOwner(Optional ByVal owner As String = "") As acSuggestions
            Dim owners As New acSuggestions
            Using conn As New SqlConnection()
                conn.ConnectionString = strConn2
                Using cmd As New SqlCommand()
                    cmd.CommandText = "select Name from county.OwnerParcel where " & "Name like @SearchText + '%'"
                    cmd.Parameters.AddWithValue("@SearchText", owner)
                    cmd.Connection = conn
                    conn.Open()
                    Using sdr As SqlDataReader = cmd.ExecuteReader()
                        While sdr.Read()
                            owners.suggestions.Add(String.Format("{0}", sdr("Name")))
                        End While
                    End Using
                    conn.Close()
                End Using
                Return owners
            End Using
        End Function
and the acSuggestions class:
Imports System
Imports System.Collections.Generic
Imports System.Linq
Imports System.Runtime.Serialization
Imports System.Text
Namespace ParcelRestServices
    Public Class acSuggestions
        Public Property suggestions() As New List(Of String)
    End Class
End Namespace
RogerF
Thank you Robert. This was useful.
