How can I use dojo.disconnect to remove a map layer I've added. My code doesn't seem to work, it adds the map layer fine but I can't remove it? Any help would be good:
<script>
var node = dojo.byId("switch1");
var eventHandle = dojo.connect(node, "onclick", function addMapLayer1(e) {
var soils1 = new ArcGISDynamicMapServiceLayer("https://map/arcgisserver/mapserver", {
opacity: 1,
"visible": true
dojo.disconnect(eventHandle);
soils1.setVisibleLayers([1]);
map.addLayer(soils1);
</script>
<html>
<div class="switch tiny" style=" float:right;padding-top:0px;">
<input class="switch-input" id="switch1" type="checkbox" name="exampleSwitch">
<label class="switch-paddle" for="switch1">
<span class="switch-active" aria-hidden="true">On</span>
<span class="switch-inactive" aria-hidden="true">Off</span>
</label>
</div>
</html>
You should use dojo/on for your event handling. From the Events section in the documentation:
Using the
on
method is preferable to usingconnect
for several reasons. First, the Dojo documentation states thatconnect
support will be removed in Dojo 2.0, and in fact,connect
is now a legacy convenience wrapper fordojo.on
. Secondly, especially in AMD style, it makes your code less verbose and is more similar to event attachment syntax in other JavaScript frameworks. Finally, foresri
components we add atarget
property to all "synthetic" events (not mouse or key events) which points to the component which fired the event.
"dojo/on" contains the function "once", which can be set so the event only happens once and is removed afterward.
Reading your question again, are you expecting disconnect to remove the layer? If so, you'll have to do that with the removeLayer method. Disconnect just removes the event handler (meaning if you click on the button again, it won't fire the function to add the map layer.
Hi Ken - thank you for the response, it's helped alot. I think my problem is the fact I'm using the same 'switch' to add the map as I am to remove it. Other than adding a different switch for each event I'm guessing I should add an if clause ie. if the map layer is 'on' and the switch is clicked again then removeLayer...
Olivia
I would use a boolean variable to "manage" the visibility of the layer and just toggle the boolean value each time the button is clicked. Then based on the boolean value set the visibility of the layer within the onclick function.
var layerIsOn = false;
layerIsOn = !layerIsOn;
if (layerIsOn) {
// switch layer on
} else {
// switch layer off
