Create Modal Panel with Tab Container
3030
08-10-2016 05:31 AM
WilliamMiller4
Since completing the Create a New Panel​ tutorial, I have been trying to add a tab container to a modified Demo widget that opens in a modal panel. I can get the content to appear, but it all displays at once and no tabs are visible. Below is an image of what currently  displays. (I highlighted the text with my mouse.) Also below are my code for Widget.html and Widget.js.
<div>
    <div class="modaltab-content" data-dojo-attach-point="customContentNode"></div>
</div>
define(['dojo/_base/declare',
    'jimu/BaseWidget',
    'dijit/_WidgetsInTemplateMixin',
    'dojo/_base/html',
    'dojo/query',
    'dojo/_base/array',
    'dojo/_base/sniff',
    'dijit/layout/TabContainer',
    'dijit/layout/ContentPane'
  function(declare, BaseWidget, _WidgetsInTemplateMixin, html, query, array, sniff, TabContainer, ContentPane) {
    return declare([BaseWidget, _WidgetsInTemplateMixin], {
      baseClass: 'jimu-widget-modaltab',
      postCreate: function() {
        this.inherited(arguments);
      startup: function() {
        var htmlFragment = '';
        var tc = new TabContainer("tc");
        //First Tab panel
        htmlFragment = htmlFragment + '<div dojo-data-type=\"dijit/layout/ContentPane\" title=\"WELCOME\" selected=\"true\">';
        theContent = '';
        theContent = theContent + '<div><h1>WELCOME</h1><br />';
        theContent = theContent + '<p>Welcome to ...</p></div>';
        var cp1 = new ContentPane({
             title: "WELCOME",
             content: theContent,
             selected: true
        tc.addChild(cp1);
        //Second Tab Panel
        theContent = '';
        theContent = theContent + '<div><h1>ABOUT</h1><br />';
        theContent = theContent + '<p>The County Auditor...</p></div>';
        var cp2 = new ContentPane({
             title: "ABOUT",
             selected: true
        tc.addChild(cp2);
        //Third Tab Panel
        theContent = '';
        theContent = theContent + '<div><h1>CONTACT</h1><br />';
        theContent = theContent + '<p>Comments and questions...</p></div>';
        var cp3 = new ContentPane({
             title: "CONTACT",
             selected: true
        tc.addChild(cp3);
        //Fourth Tab Panel
        theContent = '';
        theContent = theContent + '<div><h1>HELP</h1><br />';
        theContent = theContent + '<p>For help...</p></div>';
        var cp4 = new ContentPane({
             title: "HELP",
             selected: true
        tc.addChild(cp4);
        //tc.startup();
        this.customContentNode.appendChild(tc.domNode);
Attached is the modal panel.
Any suggestions on how to get the tabs working properly would be greatly appreciated.
William
RobertScheitlin__GISP
William,
Here is the code working (at least n my end it is):
    'jimu/BaseWidget',
    'dojo/_base/html',
    'dojo/query',
    'dojo/_base/array',
    'dojo/_base/sniff',
        var tc = new TabContainer({style: "height: 100%; width: 100%;"}, this.customContentNode);
        //First Tab panel
        var theContent = '';
             title: "WELCOME",
             selected: true
        tc.addChild(cp1);
        //Second Tab Panel
        theContent = '';
             title: "ABOUT",
             selected: true
        tc.addChild(cp2);
        //Third Tab Panel
        theContent = '';
             title: "CONTACT",
             selected: true
        tc.addChild(cp3);
        //Fourth Tab Panel
        theContent = '';
             title: "HELP",
             selected: true
        tc.addChild(cp4);
        tc.startup();
William,
    'jimu/BaseWidget',
    'dojo/_base/html',
    'dojo/query',
    'dojo/_base/array',
    'dojo/_base/sniff',
        //First Tab panel
             title: "WELCOME",
             selected: true
        tc.addChild(cp1);
        //Second Tab Panel
        theContent = '';
             title: "ABOUT",
             selected: true
        tc.addChild(cp2);
        //Third Tab Panel
        theContent = '';
             title: "CONTACT",
             selected: true
        tc.addChild(cp3);
        //Fourth Tab Panel
        theContent = '';
             title: "HELP",
             selected: true
        tc.addChild(cp4);
        tc.startup();
WilliamMiller4
It's working for me too Robert.
Thanks once again!
William
