two arcgis servers
452
08-11-2016 03:10 AM
ofrig
can i use two seperate arcgis serves with one data store?
I want to use one server as test enviroment and build cache while the other server is production.
I wnat to build the cache stragit to the datastore that the production read from.
and want to know if I can use two federate servers with the same portal.
thanks.
by Anonymous User
Not applicable
Yes you can use that without any issue
If you require any help or facing issue let me know.
RobertBorchert
Frequent Contributor III
You can have your system on two different servers or machines and set up multi node sites.  Your web adapter will direct incoming requests in a round robin fashion to send 1 request to Server1 and the next request to Server2
