Limit Records for CSV Export
1956
5
08-10-2016 06:18 AM
PatrickMcKinney1
Occasional Contributor III
Is there a way to limit how many records can be exported to CSV from the Attribute Table widget?
If not, is there a way to limit how many records can be returned from a query on the service itself?
Patrick
RobertScheitlin__GISP
Patrick,
  It is likely possible. What is the criteria that you will use to limit the records?
PatrickMcKinney1
We'd like to limit the export to 1,000 records.  It will be for a tax parcels dataset.
We're using the Enhanced Search widget, and would want the limit to apply to that tool as well, if possible.
Patrick,
Looking though the code this is going to be a lot harder then I thought. The AT widget does only export the rows you have selected to the csv.
PatrickMcKinney1
Yeah, that's what I figured.  I don't think our Tax Assessment office will be keen on people being able to export the entire tax database.
Patrick,
You mentioned that you are using the eSearch. So if you are then the eSearch will only return the maxFeatureCount that the server allows and when you export to CSV from the eSearch Search results then the export will be limited to those numbers. If you remove/uncheck the taxlot layer from the AT Widget settings then it will not be present in the AT Widget and thus you can not export all the tax lots.
