Is there any way to show dynamic layer on the top of feature layer in locallayer widget, WAB.
1273
08-09-2016 12:40 AM
ShaziaNoreen
We have a dynamic layer which we want to show on the top of feature layers in local layer widget. It is appearing behind the feature layers covering dynamic layer. Dynamic layer has customised symbols which are not appearing if added as feature layer.
Any help.
deleted-user-CQZbjNeBXm49
Occasional Contributor III
Hi Shazia,
You can do that within your "Web Appbuilder Developer Version" by doing a "Move Up" of the "Dynamic Layer" and saving it then launch to see that it works before downloading the app....That is what I did when I was faced with same
Baba
ShaziaNoreen
Hi Baba
Dynamic service displays at the bottom irrespective of the order in local layer widget. Also 'move up' is greyed out for dynamic layers in layers list after launching.
Anyway thanks for your reply.
Shazia
RobertScheitlin__GISP
Sharia,
   In the JS Api all graphics layers and feature layers are always drawn on top of all other layers in the map. This is not something that can be changed as it is an internal api limitation
