google steetview with WAB 2.1
476
08-08-2016 08:03 PM
RamS1
Good day All,
I upgraded my WAB 2.0 application from 2.0 to 2.1. My google streetview stops working after 2 seconds. I have verified I have set null value for google api code.
any idea what I am missing . what is the recommended way to upgrade?
Thanks for your help!
Tags (1)
RobertScheitlin__GISP
Ram,
   My suggestion would be to remove the StreetView widget from the app and then check the widgets folder for that app and delete the StreetView folder (if still present). Then get the 2.1 version of the widget and add it to WAB and then add it to your existing app using the normal UI.
