I´ve created a Network Dataset but I can´t use directions. The Network Dataset is working well with arcgis extension Network Analyst but didn´t allow me to select the Directions after I created my route.
Below is my network and as you can see in the button "Directions" is asking me for a length atrribute that I already have
I would like to know if someone had a similiar problem or if someone sees some problem in my network.
Type: Geodatabase-Based Network Dataset
Version: 10.1
Sources:
Edge Sources:
Ferry_boat
Streets
Junction Sources:
Entrance_Ferry
Turns:
<Global Turns>
Connectivity:
Group 1:
Edge Connectivity:
Streets (Any Vertex)
Junction Connectivity - Transfer Groups {2}:
Entrance_Ferry (Override) - Transfer Groups {2}
Group 2:
Edge Connectivity:
Ferry_boat (Any Vertex)
Junction Connectivity - Transfer Groups {1}:
Entrance_Ferry (Override) - Transfer Groups {1}
Elevation Model: None
Attributes:
Length:
Usage Type: Cost
Data Type: Double
Units Type: Meters
Use by Default: False
Source Attribute Evaluators:
Ferry_boat (From-To): Constant = 0
Ferry_boat (To-From): Constant = 0
Streets (From-To): Field
Language: VBScript
Expression: [Shape_Length]
Streets (To-From): Field
Language: VBScript
Default Attribute Evaluators:
Default Edges: Constant = 0
Default Junctions: Constant = 0
Default Turns: Constant = 0
Time:
Usage Type: Cost
Data Type: Double
Units Type: Minutes
Ferry_boat (From-To): Constant = 15
Ferry_boat (To-From): Constant = 15
Language: VBScript
Expression: [Tempo]
Language: VBScript
Expression: [Tempo]
Cost:
Usage Type: Cost
Data Type: Double
Units Type: Unknown
Use by Default: True
Language: VBScript
Expression: [Total]
Language: VBScript
Expression: [Total]
Directions:
Directions Ready: No
-Length Attribute Required
Thank you very much.
Best Regards, Andre.
continue in duplicate thread Network Dataset: Directions
