eSearch widget not opening
1393
08-01-2016 10:44 PM
Naveen_KumarKairamkonda
    eSearch widget is not opening while we are trying to open its showing some errors in console. What might be the reason.
I have added the screenshot of console(errors).
Please can anyone help???
Thanks in advance...
Tags (1)
RobertScheitlin__GISP
d ibrahim,
  Are you using the right version of the eSearch to match your version of WAB? For example if you are using WAB 2.1 you need to be using eSearch 2.1 and if you are using WAB 2.0 then you can NOT use eSearch 2.1 you need eSearch 2.0.1.4
d ibrahim,
Thnx Robert,
    I have checked version, its the problem with the version....
