Can not edit data or overwrite a AGO HFS
867
07-28-2016 11:22 AM
DougBrowning
MVP Esteemed Contributor
I have a HFS that will suddenly not let me edit any fields using the Create local copy deal in ArcMap.
I check out a local copy, update a field, check back in and no error or anything but the data does not get changed.
AND it will not let me publish over the HFS.  I get this weird error about a raster and about it being chached.  There is no raster in the publishing map at all.  Just a few very simple Feature classes form a small local FGB.  This HFS has been working fine for months.
There are no open replicas.  Seems to have started after the last AGO update.
Any ideas?
KellyGerrow
Esri Frequent Contributor
Hi Doug,
I recommend contacting Technical Support regarding this issue. They can help to troubleshoot the cause of the issue.
-Kelly
