Create a new controller widget
2770
14
07-28-2016 10:24 AM
WilliamMiller4
Occasional Contributor II
In an effort to better understand how Web AppBuilder works, I'm going through the samples provided under the Sample Code tab of Web AppBuilder for ArcGIS (Developer Edition)​​​. I'm working through Create a new controller widget​​, but I'm getting the following error when I reach step 5e​​: error:TypeError: this.createIconNode is not a function. Below is my code for the SidebarController\Widget.js. Any help would be appreciated. Thank you. William
define([
  'dojo/_base/declare',
  'jimu/PoolControllerMixin',
  'jimu/BaseWidget'
  ], function(
    declare,
    PoolControllerMixin,
    BaseWidget
  //To create a widget, you need to derive from BaseWidget.
  return declare([BaseWidget, PoolControllerMixin], {
    // DemoWidget code goes here
    //please note that this property is be set by the framework when widget is loaded.
    //templateString: template,
    baseClass: 'jimu-widget-sidebar-controller jimu-main-background',
    allConfigs: [],
    postCreate: function() {
      this.inherited(arguments);
      console.log('postCreate');
      this.allConfigs = this.getAllConfigs();
      for(var i = 0; i < this.allConfigs.length; i++) {
        this._createIconNode(this.allConfigs);
    startup: function() {
      console.log('startup');
    _createIconNode: function(iconConfig, targetNode) {
      var iconNode, iconImage;
      if(!targetNode) targetNode = this.containerNode;
      iconNode = document.createElement('DIV');
      iconNode.className = 'icon-node';
      if(iconConfig.icon) {
        iconImage = document.createElement('img');
        iconImage.src = iconConfig.icon;
      if(iconConfig.label) {
        iconNode.title = iconConfig.label;
        iconImage.alt = iconConfig.label;
      iconNode.appendChild(iconImage);
      targetNode.appendChild(iconNode);
      return iconNode;
RobertScheitlin__GISP
William,
Step 12c has some issues/typos.
it says:
  if (iconConfig.openAtStart) {...}
  // check if the icon is a group icon
  if(this._isGroupIcon(iconConfig)) {
    // if group's tooltip has not been created yet
    if(!this.groupTooltip[iconConfig.id]) {
      // create group tooltip and its content
     var groupTooltip = document.createElement('div');
      groupTooltip.className = 'group-tooltip';
      document.body.appendChild(groupTooltip);
      for(var i = 0; i < iconConfig.widgets.length; i++) {
        this._createIconNode(iconConfig.widgets, groupTooltip);
      this.groupTooltip[iconConfig.id] = groupTooltip;
and it should be: (note line 7 and 15 are this.groupTooltips... plural not singular)
    if(!this.groupTooltips[iconConfig.id]) {
      this.groupTooltips[iconConfig.id] = groupTooltip;
Jianxia Song
William,
  It looks like the doc has a typo. The functions name is _createIconNode so this.createIconNode is not a function in your code. But it looks like you have that corrected already in your posted code.
Have you tried clearing your browser cache?
WilliamMiller4
Hi Robert,
Thanks for the suggestion. After clearing my browser cache, I still had the problem. However your suggestion gave me the idea to start a new app, and now it works.
Gratefully, William
WilliamMiller4
Now I'm having trouble with step 12 in the process. However, if I add the About widget to the SidebarController, the following warnings and error appear in the console:
    Warning: no uploadUrl provided.      FileUploader.js:32
    this.movie.PercentLoaded() failed TypeError: this.movie.PercentLoaded is not a function(…)      main.js:2867
          x 17
    Uncaught Error: Building SWF failed.      main.js:2867
Even with these errors and warning, everything seems to be working through step 11 (code below).
define([
  'dojo/on',
  'dojo/query',
  'dojo/dom-class',
  'jimu/BaseWidget'
  ], function(
    declare,
    on,
    query,
    domClass,
    BaseWidget
    allConfigs: [],
    openedWidgetId: '',
    activeIconNode: null,
      // check if the widget is set to open at start
        this.activeIconNode = iconNode;
        domClass.add(iconNode, 'jimu-state-active');
        this._showWidgetContent(iconConfig);
      var self = this;
      this.own(on(iconNode, 'click', function() {
        // remove active state from any icon node
        query('.jimu-state-active', self.domNode).removeClass('jimu-state-active');
        // close panel
        // close group tooltips
        // if clicked on an active icon node
        if(self.activeIconNode === this) {
          self.panelManager.closePanel(iconConfig.id + '_panel');
          self.activeIconNode = null;
          return;
        // show panel
        domClass.add(this, 'jimu-state-active');
        self._showWidgetContent(iconConfig);
        self.activeIconNode = this;
      return iconNode;
    _showWidgetContent: function(iconConfig) {
      if(this.openedWidgetId) {
        this.panelManager.closePanel(this.openedWidgetId + '_panel');
      var self = this;
      this.panelManager.showPanel(iconConfig).then(function(widget) {
        // the panel displays successfully
        self.own(on.once(widget, 'close', function () {
          domClass.remove(self.activeIconNode, 'jimu-state-active');
      }, function (err) {
        // the panel failed to display
      this.openedWidgetId = iconConfig.id;
After I add code for step 12 (code below), I get an error if I try to create a group (error:TypeError: Cannot read property '_29' of undefined at _createIconNode Line 79). Even if I don't create a group, the widgets will no longer close.
define([
  'dojo/on',
  'dojo/query',
  'dojo/dom-class',
  'jimu/BaseWidget'
  ], function(
    declare,
    on,
    query,
    domClass,
    BaseWidget
    allConfigs: [],
    openedWidgetId: '',
    groupTooltips: {},
      var self = this;
        // close panel
        self.panelManager.closePanel(self.openedWidgetId + '_panel');
        query('.group-tooltip').removeClass('show');
          return;
        // clicking on a group icon
        if (self._isGroupIcon(iconConfig)) {
          self.openedWidgetId = null;
          self._positionTooltip(self.groupTooltips[iconConfig.id], this);
          domClass.add(self.groupTooltips[iconConfig.id], 'show');
        } else { // clicking on a widget icon
          // show panel
      return iconNode;
      var self = this;
      }, function (err) {
    _isGroupIcon: function(iconConfig) {
      return iconConfig.widgets && iconConfig.widgets.length > 1;
    _positionTooltip: function(tooltip, iconNode) {
      var iconBoundingRect = iconNode.getBoundingClientRect();
      tooltip.style.top = iconBoundingRect.top + 'px';
      tooltip.style.left = (iconBoundingRect.width || iconNode.clientWidth) + 'px';
Thank you for your time and help.
William
William,
it says:
Jianxia Song
WilliamMiller4
Hi Robert,
Thanks for your help with the groupTooltips issue. That part is working. Unfortunately, while the group widget "closes", the solo widgets stay visible after a second click (the first click for opening them). The following snippet shows where I think the issue might be located in the code.
  // close panel
////self.panelManager.closePanel(self.openedWidgetId + '_panel');            // uncomment this line and the group widget closes
//////self.panelManager.closePanel(iconConfig.id + '_panel');               // uncomment this line and the solo widgets close
    return;
Uncomment both lines 5 and 11 and only the group widget "closes."
Again, any help would be greatly appreciated.
William
William,
  Here is my complete _createIconNode function that is working fine for me:
      var self = this;
        // close panel
          return;
          // show panel
      return iconNode;
      var self = this;
      }, function (err) {
WilliamMiller4
Hi Robert,
The code is are the same...
Are your panels Simple Border Panels:                                  Or Foldable(?) Panels:
I'm having trouble with the Simple Border Panels.
Does it matter that I'm using Web AppBuilder 2.0 and not 2.1?
Thanks again and sorry to be such a bother.
William
Jianxia
Robert-- Thanks for the correction. The code update will be applied in the mid of August.
Jianxia
William,
  I was using foldable panels. Did I miss some step about the simple border panels?
