how to lock column in my shapefile?
1136
07-22-2016 07:07 AM
AbdelMounaimTAOUSSI
it will be very helpful for example lock some column key before export it for editing
Tags (3)
VinceAngelo
Esri Esteemed Contributor
You can't lock a column, only a table.  ArcGIS creates the locks required for the operation by default.
- V
AbdelMounaimTAOUSSI
but if i had a table with key( an identifier) column that shouldn't change and  i want to export data --> modify only geometry --> re-import data
( the problem is if someone edit the key --> i can't import data correctly cause i use script to add it  to database)
i think that esri think to add this function in their feature version
VinceAngelo
Databases can do any number of amazing things to prevent certain operations (at a performance cost, of course).  Shapefiles are NOT database entities, and therefore don't have any of these options available.  Even if you requested this enhancement through Ideas, and it was implemented, it's not likely that it would be implemented on shapefiles.
- V
