Is there any way to convert multipatch feature classes from a file geodatabase to an enterprise geodatabase?
877
07-21-2016 09:50 AM
CyrusBlankinship
I'm currently using 10.4 & Pro. From what I understand, this is only possible through use of a CAD object, but I have no idea what this entails.
This question continues the conversation in this thread: https//geonet.esri.com/message/622754?et=watches.email.thread#comment-622754
VinceAngelo
Esri Esteemed Contributor
Have you tried to copy the feature class to an EGDB?  It should just work (the only significance of the CAD object is that you can't access the data from SQL).
- V
