WAB - Splash Screen
3420
15
07-19-2016 02:46 PM
RickeyFight
MVP Regular Contributor
I am getting some weird behavior.
My splash screen works in the builder but when I launch the webapp or download it to my server it will not display the splash screen.
Builder:
Launched Webapp:
Here is the config.json
I did not change any code so I would think it would work. I am not getting any errors in the console log either.
        "uri": "widgets/Splash/Widget",
        "position": {
          "relativeTo": "browser"
        "version": "2.0.1",
        "id": "widgets_Splash_Widget_29",
        "name": "Splash",
        "label": "Splash",
        "config": "configs/Splash/config_Splash.json"
          "visible": true,
          "position": {
          "version": "2.0.1"
Do you have any suggestions or things I can try?
RobertScheitlin__GISP
Rickey,
  Yes that is something that I would try.
Have you created a brand new app with the splash for testing if it ends up with the same issue?
deleted-user-CQZbjNeBXm49
Occasional Contributor III
What is your "config_Splash.json" like....?
RickeyFight
  "splash": {
    "splashContent": "<div style=\"text-align: center;\"><p class=\"MsoNormal\" style=\"margin-left:.5in\"><i><font size=\"3\">“TEXT”</font><o:p></o:p></i></p></div>",
    "requireConfirm": true,
    "confirmText": "I agree to the above terms and conditions",
    "showOption": true,
    "confirmEverytime": true,
    "backgroundColor": "#0d458d"
Ricky,
  Your two code blocks in your post, which is which? Have you tried putting a break point in the Splash Widget.js code to see if you are getting to it?
RickeyFight
Robert those two blocks are the ones that refer to the splash widget in  \server\apps\3\config.json
Rickey,
  So that is strange that you have the splash referred to twice in the config.json. When I add the splash widget I only have this one object in the config.json:
        "position": {
        "version": "2.1",
        "id": "widgets_Splash_Widget_14",
        "icon": "widgets/Splash/images/icon.png?wab_dv=2.1",
        "name": "Splash",
        "label": "Splash",
RickeyFight
The first section is under widgetOnScreen and the other one is under mobileLayout
Rickey,
  So the app was downloaded from AGOL?
RickeyFight
No, I created it in WAB.
I have another test app that I made and it too would not display a splash screen when I "launched" it.
Rickey,
  Strange I have not come across this before.
