Addition operand in Survey123 XLS form
1890
07-19-2016 12:55 PM
edmundzlonis
Addition operand in math formula results in concatenation rather than sum for numeric
values.  I am trying to sum 4 previous fields to confirm that they add up
to 1.0. The following formula ${EC} + ${FLC} + ${OWC} + ${ShC} results in a
concatenation (0.40.30.20.1), rather than a sum (1.0) of the fields. The other
operands all work correctly. In the Excel spreadsheet the name cells for the
select_one field (e.g., PropCover) are defined as numeric and the type for the
recipient cell (TotalCover) is decimal. When I use the form with this formula
in ODK Collector the addition operand works correctly. Am I missing something?
Thanks.
PhilipWilson-GIS
New Contributor III
Hi Edmund. You need to cast the fields as integers for them to sum correctly and not just concatenate. Your formula should look as follows:  int(${EC}) + int(${FLC}) + int(${OWC}) + int(${ShC})
Hope that helps. Phil.
PhilipWilson-GIS
New Contributor III
bobwright
Hi Phil,
How would you cast decimals? I tried dec and decimal, but got error messages. Thanks.
Bob
IsmaelChivite
Esri Notable Contributor
Cross referencing response: Addition operand in Survey123 XLS form
