How do I get the instance of a MapTool?
1320
07-19-2016 08:11 AM
HoriaTudosie
Occasional Contributor II
I don't want to get a wrapper command (with GetPlugInWrapper.)
I just need to access some methods that I have defined in my inherited Tool class definition.
(I Think that I can identify the tool instance by its ID since I have just one instance (?))
internal class PickupTool : MapTool
        /// <summary>
        /// Define the tool as a sketch tool that draws a rectangle in screen space on the view.
        /// </summary>
        public PickupTool()
            IsSketchTool = true;
            SetSketchType(Settings.Default.GfxPickOption);
            UseSnapping = true;
            SketchOutputMode = SketchOutputMode.Screen;
       public void SetSketchType(PickToolOptions gfxPickOption)
            switch (gfxPickOption)
                case PickToolOptions.Point:
                    SketchType = SketchGeometryType.Point;
                    Cursor = GetCursor("PointCursor.cur");
                    break;
From a ribbon button/menu I need to call the method in line 14.
Tags (1)
HoriaTudosie
Found a solution:
I save the instance in the module when I create it.
HoriaTudosie
Found a solution:
NasirAhmad4
Can you please provide detail on how you did this.
Thank you,
HoriaTudosie
   /// <summary>
   /// </summary>
   public PickupTool()
      UseSnapping = true;
      Module1.GfxPickupTool = this;
Module1:
private PickupTool m_gfxPickupTool;
public static PickupTool GfxPickupTool
   get
      return Current?.m_gfxPickupTool;
   set
      if (Current != null)
         Current.m_gfxPickupTool = value;
Config.daml:
<tool id="GFXModule_PairTool" caption="Pair Feature" className="PickupTool" loadOnClick="true" smallImage="Images\Rings32.png" largeImage="Images\Rings32.png" condition="esri_mapping_mapPaneOrLayoutPane">
<tooltip heading="Pair">
Pair Feature from the Map<disabledText /></tooltip>
</tool>
NasirAhmad4
Thank you for your quick reply.
