How to set non-overlapping point symbology.
4135
7
07-14-2016 11:41 AM
DevinUnderwood2
I know that symbology has limited functionality in placing symbols. Maplex can be used to
create as text symbols, which I did. I also tried using leader lines which I don’t like.
My question is, do you have any recommendations on how to address overlapping features symbology?
Is creating feature representations a viable option?
Thank you.
ChrisDonohue__GISP
One possibility is to create point Representations, then use the Disperse Markers Cartographic Refinement Tool.  Note that this requires an Advanced License and this tool is a more recent innovation, so if you are using an older copy of ArcGIS it may not be available.
Disperse Markers—Help | ArcGIS for Desktop
Chris Donohue, GISP
ChrisDonohue__GISP
Chris Donohue, GISP
DevinUnderwood2
Looks Like I will learn how to create representations, and try the Disperse Markers which I have come across in my researching this subject.  Thanks for the advice.
DanPatterson_Retired
this is what you are referring to I assume? Offsetting point labels—Help | ArcGIS for Desktop
AnninaHirschiWyss
Occasional Contributor II
Hi all,
I have a similar issue, but:
- The disperse marker doesn't work on multi point FC
- In Pro, the disperse marker modifies the geometry (Representations are not yet supported)
- Working with labels doesn't work for me (2 fields based "multilayer" symbology)
- Offsetting a symbol isn't an option either, as not always the same types are "clustered" together
- Need to show the exact location as well (e.g. with leader lines)
- Setting reference scale doesn't solve the overlap issue (either the symbols overlap, or they get too small to distinguish)
So something like that: https://community.esri.com/ideas/5998  would be awesome, but it's not yet available.
Any other ideas? Go back to ArcMap and into representations?
Thx
DevinUnderwood3
New Contributor III
I suggest using ArcMap representations as I did very successfully.
AnninaHirschiWyss
Hi Devin,
Unfortunately representations do not solve my issue, as there are sometimes points of the same symbology-type overlap (offsetting will not disperse them, they just move into the same direction) and I need to have something like a leader line to show the exact location...
Thanks anyway.
DevinUnderwood3
New Contributor III
Have you tried to edit the representation points (not actual features) individually by placing them in their exact location ?
