Edit Widget in configurable app will not work when upgraded to WAB 2.0.
1354
07-14-2016 08:20 AM
MichaelTorbett1
Hello Everyone,
I recently upgraded my apps from WAB 1.3 to 2.0. One app is configurable and can be pointed to any web map and then edited with the 'Editor Widget.' However since I've upgraded, the edit widget will no longer work (just a blank window with the never ending spinning wheel). All of the settings and code are the same as far as I can tell. Has anyone else had this issue?
MichaelTorbett1
Well that was the problem. I re-downloaded it again and now everything's working fine. Thanks for your input Robert.
RobertScheitlin__GISP
Michael,
  Have you tried starting a new app and see if it has the same issues?
MichaelTorbett1
Hey Robert,
Yes I've tried creating a new app and still getting the same issues. At this point I may try re downloading WAB and see if that works.
MichaelTorbett1
