Add the image on the map using coordinates of four angular points of the image in ArcGIS SDK for .NET?
1936
07-13-2016 05:54 AM
SergeyLomovskikh
I want to add my local image on the map using coordinates of four angular points of the image with result like in ArcGISImageServiceLayer example. What ways are?
MichaelBranscomb
Esri Frequent Contributor
If you're currently working with 10.2.7 and are not ready to upgrade to the new Quartz Beta (note there are some significant changes) then I would recommend using KML and GroundOverlays.
In the new Beta we have added direct support for raster data. If your raster data does not have any geo-referencing information embedded in the file and does not have any associated geo-referencing information in external files then you can create a world file. For more info see World files for raster datasets—Help | ArcGIS for Desktop
Cheers
Mike
SergeyLomovskikh
Thanks for the answer. Is Mapview.Editor available in Beta?
MichaelBranscomb
Unfortunately the new SketchEditor was not available in beta, but it is included in the full release (v100.0): ArcGIS Runtime SDK for .NET | ArcGIS for Developers
Cheers
Mike
