closestFacilityTask from a csv
1424
07-07-2016 07:56 AM
JimColl
I am attempting to modify the closestFacilityTask sample (ArcGIS API for JavaScript Sandbox ) to take a csv input as the facilities layer, but have not had any luck.  Any tips as to where I have gone wrong would be greatly appreciated.  You can copy/paste the code below into the sandbox to see how I've attempted to approach this problem.
<!DOCTYPE html>
<html>
<head>
  <title>Closest Facilities</title>
  <link rel="stylesheet" href="https://js.arcgis.com/3.17/dijit/themes/claro/claro.css">
  <link rel="stylesheet" href="https://js.arcgis.com/3.17/esri/css/esri.css">
  <style>
    body,html,#main{margin:0;padding:0;height:100%;width:100%;}
    .panel {
      border-radius: 6px;
      box-shadow: 0px 6px 3px -3px #888;
      border: 2px solid #86942A;
      margin: 5px;
  </style>
  <script src="https://js.arcgis.com/3.17/"></script>
  <script>
    var map, params;
    require([
      "dojo/dom",
      "dojo/_base/array",
      "esri/Color",
      "dojo/parser",
      "dijit/registry",
      "esri/urlUtils",
      "esri/map",
      "esri/lang",
      "esri/graphic",
      "esri/InfoTemplate",
      "esri/layers/GraphicsLayer",
      "esri/renderers/SimpleRenderer",
      "esri/geometry/Point",
      "esri/tasks/FeatureSet",
      "esri/tasks/ClosestFacilityTask",
      "esri/tasks/ClosestFacilityParameters",
      "esri/symbols/SimpleMarkerSymbol",
      "esri/symbols/SimpleLineSymbol",
      "esri/layers/CSVLayer",
      "dijit/form/ComboBox",
      "dijit/layout/BorderContainer",
      "dijit/layout/ContentPane"
    ], function(
      dom, array, Color, parser, registry,
      urlUtils, Map, esriLang, Graphic, InfoTemplate, GraphicsLayer, SimpleRenderer,
      Point, FeatureSet,
      ClosestFacilityTask, ClosestFacilityParameters,
      SimpleMarkerSymbol, SimpleLineSymbol, CSVLayer
      var incidentsGraphicsLayer, routeGraphicLayer, closestFacilityTask;
      map = new Map("map", {
        basemap: "streets",
        center: [-87.540526, 33.215858],
        zoom: 13,
        showInfoWindowOnClick: false
      var facilityPointSymbol = new SimpleMarkerSymbol(
        SimpleMarkerSymbol.STYLE_SQUARE,
        20,
        new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new Color([89,95,35]), 2),
        new Color([130,159,83,0.40])
      var incidentPointSymbol = new SimpleMarkerSymbol(
        SimpleMarkerSymbol.STYLE_CIRCLE,
        16,
      var routePolylineSymbol = new SimpleLineSymbol(
        4.0
      shelterPointSym = new SimpleRenderer(facilityPointSymbol);
      parser.parse();
      urlUtils.addProxyRule({
        urlPrefix: "route.arcgis.com",
        proxyUrl: "/sproxy/"
        urlPrefix: "mikecp11.github.io",
        proxyUrl: "/proxy/"
      shelters = new CSVLayer("https://mikecp11.github.io/LocalStops.csv", {
        geometryType:"esriGeometryPoint",
        latitudeFieldName:"LATITUDE",
        longitudeFieldName:"LONGITUDE"//,
        //refreshInterval:5,
        //renderer: shelterPointSym,
        //styling: true,
        //visible: true
      console.log(shelters)
      map.on("click", mapClickHandler);
      params = new ClosestFacilityParameters();
      params.impedenceAttribute= "Miles";
      params.defaultCutoff= 400;
      params.returnIncidents=false;
      params.returnRoutes=true;
      params.returnDirections=true;
      //params.defaultTargetFacilityCount=5;
      map.on("load", function(evtObj) {
        var map = evtObj.target;
        incidentsGraphicsLayer = new GraphicsLayer();
        var incidentsRenderer = new SimpleRenderer(incidentPointSymbol);
        incidentsGraphicsLayer.setRenderer(incidentsRenderer);
        map.addLayer(incidentsGraphicsLayer);
        routeGraphicLayer = new GraphicsLayer();
        var routeRenderer = new SimpleRenderer(routePolylineSymbol);
        routeGraphicLayer.setRenderer(routeRenderer);
        map.addLayer(routeGraphicLayer);
        var facilitiesGraphicsLayer = new GraphicsLayer();
        var facilityRenderer = new SimpleRenderer(facilityPointSymbol);
        facilitiesGraphicsLayer.setRenderer(facilityRenderer);
        map.addLayer(facilitiesGraphicsLayer);
        facilitiesGraphicsLayer.add(shelters.graphics);
        // facilitiesGraphicsLayer.add(new Graphic(new Point(-9747535,3911614,map.spatialReference)));
        // facilitiesGraphicsLayer.add(new Graphic(new Point(-9744043,3912399,map.spatialReference)));
        // facilitiesGraphicsLayer.add(new Graphic(new Point(-9739868,3914969,map.spatialReference)));
        // facilitiesGraphicsLayer.add(new Graphic(new Point(-9736724,3915954,map.spatialReference)));
        // facilitiesGraphicsLayer.add(new Graphic(new Point(-9730781,3920702,map.spatialReference)));
        // facilitiesGraphicsLayer.add(new Graphic(new Point(-9733535,3926914,map.spatialReference)));
        // facilitiesGraphicsLayer.add(new Graphic(new Point(-9740003,3923150,map.spatialReference)));
        // facilitiesGraphicsLayer.add(new Graphic(new Point(-9741618,3925577,map.spatialReference)));
        // facilitiesGraphicsLayer.add(new Graphic(new Point(-9737357,3927660,map.spatialReference)));
        // facilitiesGraphicsLayer.add(new Graphic(new Point(-9742319,3929506,map.spatialReference)));
        // facilitiesGraphicsLayer.add(new Graphic(new Point(-9745587,3926974,map.spatialReference)));
        // facilitiesGraphicsLayer.add(new Graphic(new Point(-9747498,3925474,map.spatialReference)));
        // facilitiesGraphicsLayer.add(new Graphic(new Point(-9748919,3929392,map.spatialReference)));
        // facilitiesGraphicsLayer.add(new Graphic(new Point(-9751928,3931523,map.spatialReference)));
        // facilitiesGraphicsLayer.add(new Graphic(new Point(-9749396,3926593,map.spatialReference)));
        // facilitiesGraphicsLayer.add(new Graphic(new Point(-9755206,3927204,map.spatialReference)));
        // facilitiesGraphicsLayer.add(new Graphic(new Point(-9753961,3919552,map.spatialReference)));
        // facilitiesGraphicsLayer.add(new Graphic(new Point(-9749212,3919246,map.spatialReference)));
        // facilitiesGraphicsLayer.add(new Graphic(new Point(-9744368,3919733,map.spatialReference)));
        // facilitiesGraphicsLayer.add(new Graphic(new Point(-9739447,3916112,map.spatialReference)));
        // facilitiesGraphicsLayer.add(new Graphic(new Point(-9732664,3917186,map.spatialReference)));
        // facilitiesGraphicsLayer.add(new Graphic(new Point(-9731322,3924282,map.spatialReference)));
        // facilitiesGraphicsLayer.add(new Graphic(new Point(-9736491,3922677,map.spatialReference)));
        // facilitiesGraphicsLayer.add(new Graphic(new Point(-9739739,3921100,map.spatialReference)));
        // facilitiesGraphicsLayer.add(new Graphic(new Point(-9741564,3921033,map.spatialReference)));
        // facilitiesGraphicsLayer.add(new Graphic(new Point(-9744947,3921339,map.spatialReference)));
        // facilitiesGraphicsLayer.add(new Graphic(new Point(-9747249,3923021,map.spatialReference)));
        // facilitiesGraphicsLayer.add(new Graphic(new Point(-9747001,3923661,map.spatialReference)));
        // facilitiesGraphicsLayer.add(new Graphic(new Point(-9745042,3923470,map.spatialReference)));
        // facilitiesGraphicsLayer.add(new Graphic(new Point(-9743504,3922839,map.spatialReference)));
        // facilitiesGraphicsLayer.add(new Graphic(new Point(-9740685,3923841,map.spatialReference)));
        // facilitiesGraphicsLayer.add(new Graphic(new Point(-9738354,3924177,map.spatialReference)));
        // facilitiesGraphicsLayer.add(new Graphic(new Point(-9739797,3926823,map.spatialReference)));
        var facilities = new FeatureSet();
        facilities.features = facilities.graphics;
        params.facilities = facilities;
        params.outSpatialReference = map.spatialReference;
        map.addLayer(shelters);
      closestFacilityTask = new ClosestFacilityTask("https://route.arcgis.com/arcgis/rest/services/World/ClosestFacility/NAServer/ClosestFacility_World");
      registry.byId("numLocations").on("change", function() {
        params.defaultTargetFacilityCount = this.value;
        clearGraphics();
      function clearGraphics() {
        //clear graphics
        dom.byId("directionsDiv").innerHTML= "";
        map.graphics.clear();
        routeGraphicLayer.clear();
        incidentsGraphicsLayer.clear();
      function mapClickHandler(evt) {
        clearGraphics();
        var inPoint = new Point(evt.mapPoint.x, evt.mapPoint.y, map.spatialReference);
        var location = new Graphic(inPoint);
        incidentsGraphicsLayer.add(location);
        var features = [];
        features.push(location);
        var incidents = new FeatureSet();
        incidents.features = features;
        params.incidents = incidents;
        map.graphics.enableMouseEvents();
        routeGraphicLayer.on("mouse-over", function(evt){
          //clear existing directions and highlight symbol
          dom.byId("directionsDiv").innerHTML= "Hover over the route to view directions";
          var highlightSymbol = new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new Color([0,255,255],0.25), 4.5);
          var highlightGraphic = new Graphic(evt.graphic.geometry,highlightSymbol);
          map.graphics.add(highlightGraphic);
          dom.byId("directionsDiv").innerHTML = esriLang.substitute(evt.graphic.attributes,"${*}");
        //solve
        var destinationArray = [];
        closestFacilityTask.solve(params, function(solveResult){
          array.forEach(solveResult.routes, function(route, index){
            //build an array of route info
            var attr = array.map(solveResult.directions[index].features, function(feature){
              return feature.attributes.text;
            var infoTemplate = new InfoTemplate("Attributes", "${*}");
            route.setInfoTemplate(infoTemplate);
            route.setAttributes(attr);
            //alert(JSON.stringify(route.attributes[route.attributes.length - 1], null, 4));
            destinationArray.push(route.attributes[route.attributes.length - 1])
            routeGraphicLayer.add(route);
            dom.byId("directionsDiv").innerHTML = "Hover over the route to view directions";
          alert(destinationArray.toString());
          //display any messages
          if(solveResult.messages.length > 0){
            dom.byId("directionsDiv").innerHTML = "<b>Error:</b> " + solveResult.messages[0];
  </script>
</head>
<body class="claro">
  <div data-dojo-type="dijit/layout/BorderContainer"
       data-dojo-props="design:'headline', gutters:false"
       style="width:100%;height:100%;margin:0px;">
    <div id="map"
         data-dojo-type="dijit/layout/ContentPane"
         data-dojo-props="region:'center'" class="panel">
    </div>
    <div id="directions"
         data-dojo-props="region:'bottom'" class="panel"
         style="height:250px;">
      <b>Click the map to find names and addresses for the
      <select id="numLocations" name="numLocations" data-dojo-type="dijit/form/ComboBox" value="1" style="width:60px;">
          <option selected="selected">1</option>
          <option>2</option>
          <option>3</option>
          <option>4</option>
          <option>5</option>
      </select> closest shelters to your location.</b>
      <div id="directionsDiv"></div>
    </div>
</div>
</body>
</html>
JimColl
For future internet trollers, we got around this problem like so (it's not pretty but it works):
        function initStops(){
          console.log("initStops started");
          var sheltersActiveSymbol = new SimpleMarkerSymbol("solid", 12, null, new Color([0, 100, 0, 0.5]));
          var sheltersInactiveSymbol = new SimpleMarkerSymbol(SimpleMarkerSymbol.STYLE_X, 10, new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new Color([255, 0, 0, 0.5]), 4));
          var sheltersActiveRenderer = new SimpleRenderer(sheltersActiveSymbol);
          var sheltersInactiveRenderer = new SimpleRenderer(sheltersInactiveSymbol);
          sheltersActive = new GraphicsLayer();
          sheltersInactive = new GraphicsLayer();
          sheltersActive.setRenderer(sheltersActiveRenderer);
          sheltersInactive.setRenderer(sheltersInactiveRenderer);
          var template = new InfoTemplate("${Name}", "Active: ${Active}");
          map.addLayer(sheltersActive);
          map.addLayer(sheltersInactive);
          function getShelters( scriptUrl ) {
            var result = null;
            $.ajax({
              url: scriptUrl,
              type: 'get',
              dataType: 'text',
              async: false,
              success: function(data) {
                result = data;
            return result;
          $(document).ready(function(){
            csvData = getShelters("https://mikecp11.github.io/RedCrossShelters_shortened.csv");
          var csvArrays = $.csv.toArrays(csvData);
          console.log("csvarray[0]: ",csvArrays[1][0]);
          for(i=1; i < csvArrays.length; i++){
            current = csvArrays;
            shelter = new Point(current[4], current[3]);
            if (current[0] == 1) {
              sheltersActive.add(new Graphic(shelter));
            else if (current[0] == 0) {
              sheltersInactive.add(new Graphic(shelter));
          facilities.features = sheltersActive.graphics;
          console.log("initStops finished");
JimColl
            var result = null;
            $.ajax({
              url: scriptUrl,
              type: 'get',
              dataType: 'text',
              async: false,
                result = data;
            return result;
