Use a picture / graphic to label a feature
2658
07-01-2016 03:22 PM
AnthonyCheesman1
Occasional Contributor II
Hi
I've got an interesting project that I'm going to start working on next week, and I'm not quite sure how to tackle it.
I need to make a series of overview maps with an overlay of the map extents of my topographic map library. This in itself is easy enough to do. The catch is, I would like to label each extent / tile feature with a QR barcode, which will be available as as an image.
I know I can use pictures as label features - however there are several hundred map extent features and I don't want to label them all individually!
What are my options for using the QR codes as labels? The two options I can immediately think of (but are untested) is either to load the QR code into my map tile FC as a BLOB feature, or include a file path to the QR code.
Does anyone have any bright ideas? Thanks!
Tags (3)
AnthonyCheesman1
For those playing at home, the answer was that each QR had to be loaded as a layer, and georeferenced to the correct location and scale.
The georeferencing was able to be batched up as a Python script.
More details at arcpy.Warp_management not performing as expected
AnthonyCheesman1
