I have built a network dataset using the esri roads that are set up for network use. When an analysis gets to the state line it wont go past it. I didnt create the network, but what are some things i can look for to as possible causes? The roads in each state look connected topologically to the corresponding road in the adjacent state. They also look to have the same elevation and class attributes. Is there something in the attributes or network dataset properties i should look for that might be stopping this? One thing i did notice is that it looks like two junctions are created at this intersection instead of just one
I hope the junction isn't being treated as a dead end? You might want to examine the properties of the segments and see if they are indeed physically joined.
