search and route solving fuctions
2006
6
07-05-2016 06:36 AM
MuhamedRedzic
Hello, i'm using the search and the route solving functions. The thing is, sometimes i can find a point on the map with the search function, but the same text can't be reused to mark the start/end point for the route solving function. Is there a solution for this ?
Thanks for you help
Tags (3)
PanagiotisPapadopoulos
try to take the location from search tool and pass this as direction stop on direction widget
location is the geometry from search result
location = webMercatorUtils.webMercatorToGeographic(location);
var CoordsforStop = "" + location.x + "," + location.y +"";
directions.updateStop(CoordsforStop,1);
MuhamedRedzic
Thanks for your answer, but i don't really understand.
how can i get the location out of this :
var searchFrom = new Search({
   map: map
}, "fromTxf");
thanks again for your help
You can use the select - results event in order to identify the selected item from the list
Search | API Reference | ArcGIS API for JavaScript 3.17
from the result take the item geometry and push it on location parameter.
something like that
require([
], function( ... )
   on
(s,'select-result', function(e) {
      var location = e.geometry;
MuhamedRedzic
Thanks for your help it worked in the end !
glad to help you. if you want mark the question as correct answer.
