SDK EditBox OnEnter event firing twice
2350
06-28-2016 04:34 AM
by Anonymous User
Not applicable
I've added an SDK "EditBox" control to my Add-In tab, however I've got a problem where the override method "OnEnter" is firing twice when I type some text and hit enter.
My className property of my editBox in the XAML points to the following class - but hitting enter triggers the method twice.
using System.Linq;
using ArcGIS.Desktop.Framework;
namespace Pro.Test
    internal class TestEditBox : ArcGIS.Desktop.Framework.Contracts.EditBox
        public TestEditBox()
            Text = "";
        protected override void OnEnter() //this fires twice on a single keypress
            Messagebox.Show("enter pressed");
Any ideas? Is it firing on keydown then on keyup again in error?
EDIT: the method also fires when I right click the editBox, what's going on?
Regards,
Luke
UmaHarano
Hi Luke
I have passed  on your findings to the Framework team - I don't have estimate as to when it will be fixed. I will keep you posted.
Uma
by Anonymous User
Not applicable
Thank you Uma.
