Export Report with Definition Query
2969
7
06-27-2016 08:44 AM
DianeKassing
Trying to export individual report for each row in a layer.  Seems the definition query piece is not working.  Any ideas?  Code is :
import arcpy, os
path = os.getcwd()
mxd = arcpy.mapping.MapDocument("CURRENT")
lyr = arcpy.mapping.ListLayers(mxd, "BOB.TEST")[0]
fields = ['GLUE_ID']
with arcpy.da.SearchCursor(lyr, Fields) as cursor:
   for row in cursor:
        play = (row[0])
        arcpy.mapping.ExportReport(lyr,
                               r"C:\\Bob\\ExecutiveSummary.rlf",
                               r"C:\\Bob"+str(play)+".pdf",
                               "DEFINITION_QUERY",
                               report_definition_query="GLUE_ID="+str(play)+"")
del mxd
WesMiller
Regular Contributor III
You used to different spellings of fields,Fields. Does your definition query work if used in a regular query? You should be using AddFieldDelimiters—Help | ArcGIS for Desktop in case you are mixing geodatabases and shapefiles
DianeKassing
Wes - was just a typo on fields/Fields.  Changed the field delimiters - thanks!  Still getting problem with  arcpy.mapping.ExportReport line.  Here's error:
Runtime error
  File "<string>", line 9, in <module>
  File "c:\program files (x86)\arcgis\desktop10.2\arcpy\arcpy\utils.py", line 181, in fn_
    return fn(*args, **kw)
  File "c:\program files (x86)\arcgis\desktop10.2\arcpy\arcpy\mapping.py", line 515, in ExportReport
    return report_source._arc_object.ExportReport(*gp_fixargs((report_layout_file, output_file, dataset_option, report_title, starting_page_number, page_range, report_definition_query, extent, field_map), True))
RuntimeError: Error in generating report
WesMiller
Could you re-post your corrected code?
Code Formatting... the basics++
Did you check if  "GLUE_ID="+str(play)+"" returns anything?
DianeKassing
import arcpy, os
path = os.getcwd()
lyr = arcpy.mapping.ListLayers(mxd, "UNV.TEST")[0]
fields = "GLUE_ID"
with arcpy.da.SearchCursor(lyr, fields) as cursor:
   for row in cursor:
        play = (row[0])
        arcpy.mapping.ExportReport(lyr, r"C:\\Bob\\ExecutiveSummary.rlf", r"C:\\Bob"+str(play)+".pdf", "DEFINITION_QUERY", report_definition_query="GLUE_ID="+str(play))
del mxd
Yes the query alone returns the values of GLUE_ID.
WesMiller
See if this will work
import arcpy, os
path = os.getcwd()
fields = "GLUE_ID"
   for row in cursor:
        play = (row[0])
        sql_exp = """{0} = '{1}'""".format(
            arcpy.AddFieldDelimiters(lyr, fields),
            play)
        arcpy.mapping.ExportReport(lyr, r"C:\\Bob\\ExecutiveSummary.rlf", r"C:\\Bob"+str(play)+".pdf", "DEFINITION_QUERY", report_definition_query = sql_exp)
del mxd
DianeKassing
Wes - Brilliant!  Works great.  Thanks!!  Can you elaborate on the logic behind needing the sql expression for ExportReport?
WesMiller
The logic is simply formatting the query correctly to make the query work. using the AddFieldDelimiters ensures the field names gets the proper characters around them.whether it is a feature class from a file, personal, arcgis server geodatabase or a shapefile.
