Hello
in http://resources.arcgis.com/en/help/arcgis-rest-api/#/Vehicle_Routing_Problem_service/02r3000000n400... There are fields of type TIME, but do not quite understand as I have to enter them.
for example:
orders={"features":[{"geometry":{"x":-122.51,"y":37.7724},"attributes":{"TimeWindowStart1":1355245200000,"TimeWindowEnd1":1355274000000,"MaxViolationTime1":0}}
as I can know that this value corresponds date: 1355245200000?
and how I can convert a date format that I must enter the API: 06/25/2016 08: 15hs AM?
Solved! Go to Solution.
The time used is epoch time (or Unix time) - the number of milliseconds since 1 Jan 1970 (usually in UTC, so you may need to convert to/from local time). Search for code that will convert to and from this time. Here's a python sample.
import datetime, time
epoch_time = int(time.mktime(datetime.datetime.now().timetuple()) * 1000)
print epoch_time
print time.strftime('%Y-%m-%d %H:%M:%S', time.localtime(int(epoch_time/1000)))
my_time = 1355245200000
print time.strftime('%Y-%m-%d %H:%M:%S', time.localtime(int(my_time/1000)))
print int(time.mktime(time.strptime('2012-12-11 08:00:00','%Y-%m-%d %H:%M:%S'))* 1000)
print epoch_time
hello
It was so simple to multiply by a thousand when sending dates on the api and divide by a thousand when I print dates to return the api.
thank you very much for your help
