notification
1568
06-23-2016 07:25 AM
albavoli
New Contributor III
is there any api for calling notification when the user is near one point in the map?
LucasDanzinger
Esri Frequent Contributor
Maybe this sample can get you on the right track - RuntimeQtSamples/offline_geofence at master · ldanzinger/RuntimeQtSamples · GitHub
However, actual push notifications are not supported by Qt itself at this point. You can either write your own in Java/Obj C, and expose through Qt, or you could look into a third party option, like v-play if you need actual push notifications - Notification Plugin | V-Play 2.8 | V-Play Engine
