Following is the code on which I am working. It is allowing to click the features to get the queried info window.
I am looking for the hover option, instead of clicking. Any help, please.
require([ "esri/InfoTemplate", "esri/dijit/Legend", "esri/symbols/SimpleFillSymbol", "esri/symbols/SimpleLineSymbol", "esri/tasks/query", "esri/tasks/QueryTask", "esri/tasks/LegendLayer", "dojo/on", "dijit/registry", "esri/dijit/BasemapGallery", "esri/geometry/webMercatorUtils", "esri/layers/ArcGISDynamicMapServiceLayer", "esri/layers/FeatureLayer", "dojo/dom", "dojo/dom-construct", "dojo/parser", "dojo/_base/array", "dijit/layout/AccordionContainer", "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dijit/TitlePane", ], function ( Graphic, SpatialReference, Extent, GraphicsLayer, Color, InfoTemplate, Legend, SimpleFillSymbol, SimpleLineSymbol, Query, QueryTask, LegendLayer, on, registry, BasemapGallery, webMercatorUtils, ArcGISDynamicMapServiceLayer, FeatureLayer, dom, domConstruct, parser, arrayUtils, AccordionContainer, BorderContainer, ContentPane, TitlePane ) { parser.parse(); var legendLayers = []; var map = new esri.Map("map", { basemap: "topo", center: [-110, 47], zoom: 6 }); /* Add the BASEMAP GALLERY from ESRI */ var basemapGallery = new BasemapGallery( ); /********************************************************* HISTORIC QUAKES FEATURE LAYER *********************************************************/ /* Create a new InfoTemplate for the MBMG SWAMP layer 2014-12-29 */ var historicInfoTemplate = new InfoTemplate(); historicInfoTemplate.setTitle("SWAMP Record ${GWICId}"); historicInfoTemplate.setContent("<table>" + "<tr valign='top'><td style='white-space:nowrap;'>Event Date</td><td>${Date_}</td></tr>" + "<tr><td style='white-space:nowrap;'>Location</td><td style='white-space:nowrap;'>${Lat}, ${Long_}</td></tr>" + "<tr><td style='white-space:nowrap;'>Magnitude</td><td style='white-space:nowrap;'>${Mag}</td></tr>" + "<tr><td style='white-space:nowrap;'>Approx Location</td><td>${Approximate_Location}</td></tr>" + "<tr><td style='white-space:nowrap;'>Source</td><td>${Source}</td></tr>" + "<tr><td style='white-space:nowrap;'>Other Info</td><td><a href='${Link}' target='_newwindow'>${Link}</a></td></tr>" + "</table>"); var historicQuakesFeatureLayer = new FeatureLayer("http://mbmgmap.mtech.edu/ArcGIS/rest/services/quakes/Historic_quakes/MapServer/0", { mode: FeatureLayer.MODE_SNAPSHOT, outFields: ["Date_", "Lat", "Long_", "Mag", "Approximate_Location", "Source", "Link"], infoTemplate: historicInfoTemplate } ); map.addLayers([historicQuakesFeatureLayer]); /* Re-size the infoWindow to fit the standard contents */ map.infoWindow.resize(350, 150); });
Solved! Go to Solution.
Bulbul,
Here is a sample working with your data:
<!DOCTYPE html> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable= no"> <title>Feature Layer - display results as an InfoWindow onHover</title> <link rel="stylesheet" href="https://js.arcgis.com/3.16/dijit/themes/tundra/tundra.css"> <link rel="stylesheet" href="https://js.arcgis.com/3.16/esri/css/esri.css"> <style> html, body, #mapDiv { padding: 0; margin: 0; height: 100%; } #mapDiv { position: relative; } </style> <script src="https://js.arcgis.com/3.16/"></script> <script> var map, to; require([ "esri/map", "esri/InfoTemplate", "dojo/on", "esri/layers/FeatureLayer", "dojo/domReady!" ], function( Map, InfoTemplate, on, FeatureLayer ) { var map = new Map("mapDiv", { basemap: "topo", center: [-110, 47], zoom: 6 }); /********************************************************* HISTORIC QUAKES FEATURE LAYER *********************************************************/ /* Create a new InfoTemplate for the MBMG SWAMP layer 2014-12-29 */ var historicInfoTemplate = new InfoTemplate(); historicInfoTemplate.setTitle("SWAMP Record ${GWICId}"); historicInfoTemplate.setContent("<table>" + "<tr valign='top'><td style='white-space:nowrap;'>Event Date</td><td>${Date_}</td></tr>" + "<tr><td style='white-space:nowrap;'>Location</td><td style='white-space:nowrap;'>${Lat}, ${Long_}</td></tr>" + "<tr><td style='white-space:nowrap;'>Magnitude</td><td style='white-space:nowrap;'>${Mag}</td></tr>" + "<tr><td style='white-space:nowrap;'>Approx Location</td><td>${Approximate_Location}</td></tr>" + "<tr><td style='white-space:nowrap;'>Source</td><td>${Source}</td></tr>" + "<tr><td style='white-space:nowrap;'>Other Info</td><td><a href='${Link}' target='_newwindow'>${Link}</a></td></tr>" + "</table>"); var historicQuakesFeatureLayer = new FeatureLayer("http://mbmgmap.mtech.edu/ArcGIS/rest/services/quakes/Historic_quakes/MapServer/0", { mode: FeatureLayer.MODE_SNAPSHOT, outFields: ["Date_", "Lat", "Long_", "Mag", "Approximate_Location", "Source", "Link"], infoTemplate: historicInfoTemplate }); map.addLayers([historicQuakesFeatureLayer]); historicQuakesFeatureLayer.on("mouse-over", function(evt){ map.infoWindow.setFeatures([evt.graphic]); map.infoWindow.show(evt.graphic.geometry); clearTimeout(to); }); historicQuakesFeatureLayer.on("mouse-out", function(evt){ to = setTimeout(function(){ map.infoWindow.hide(); }, 500); }); /* Re-size the infoWindow to fit the standard contents */ map.infoWindow.resize(350, 150); }); </script> </head> <body class="tundra"> <div id="mapDiv"></div> </body> </html>
Bulbul,
Thank you...this works.....Regards
Hi there is there any way that I can actually go in there I mean in that pop up there is a hyperlink and it is not possible to use it....Any help will be appreciated.
Sure just adjust the timeout:
}, 2000);
Thank you Robert, I appreciate it.
Regards
Bulbul
