geodatabases administration
1492
6
06-21-2016 06:26 AM
HananeSATHI
Hi, Can I administrate geodatabases directely from sql server without using arcpy fonctions
JakeSkinner
Esri Esteemed Contributor
Hi Hanane,
Can you elaborate a little more, for example, what type of administration are you looking to perform?
HananeSATHI
thanks for your collaboration,
I have a solution built as arcMap Adding, this solution use a multiuser geodatabase.
I would like to bring out this solution from ArcGIS platform. to release it from licence obligation.
JoshuaBixby
MVP Esteemed Contributor
As asked for already, a specific example would allow people to give more in-depth responses.  If you think your code is worth something and don't want to disclose it, that is your call, but at least give a specific example of what your code is doing in terms of administration.
HananeSATHI
thanks for your reply,
this time, i will try to explain better.
What i meant by administration all basic tasks used by the most part of applications:
- Create a new geodatabase based on a model (XML)
- Create users and roles
- load data to database
- visualize data (attribute data and if possible graphic data)
- update data ...
George_Thompson
Esri Frequent Contributor
There are some functions that you could perform from the SQL Server side, depending on the Geometry storage. But most of the enterprise geodatabase related functions will need some sort arcpy or ArcGIS Desktop component, as far as I know. Especially is you are using versioning within the enterprise geodatabase or other geodatabase functionality.
Geodatabase maintenance—Help | ArcGIS for Desktop  - For SQL Server
What is a geodatabase?—ArcGIS Help | ArcGIS for Desktop  - Good explanation of a geodatabase.
GeodatabaseEnterprise GIS
--- George T.
HananeSATHI
thanks for your response
