AnsweredAssumed Answered
ARCGIS 10, VB.NET, calculate centroids
Question asked by acoucite on Jun 17, 2016
Latest reply on Jun 23, 2016 by acoucite
  I have migrated an toolbar initially developped for ArcGis 9,3. This tool is used by non-programmer or cartographers.
  One procedure is called to generate centroids of attributes table and after to launch an calculation.
  Anyway,
  The source code used in 9,3 was :
  (A)
'instantiating new calculator and cursor
  pCalculator = New Calculator
  pCursor = CType(pFeatureClass.Update(Nothing, True), ICursor)
    'Centroid Y
  With pCalculator
  .Cursor = pCursor
.PreExpression = "Dim pGeomShp as IGeometry" & vbNewLine & "Set pGeomShp = [shape]" & vbNewLine & "Dim pArea as IArea" & vbNewLine & "Set pArea = pGeomShp" & vbNewLine
.Expression = "pArea.Centroid.Y"
  .Field = "centroidY"
  End With
    'try & catch *************************************************
  Try
pCalculator.Calculate()
  Catch ex As System.Exception
MessageBox.Show("Error: " + ex.Message)
  End Try
  This was working until moving to ArcGis 10 (an upper). A crash was observed while launching pCalculator.Calculate().
  I’ve migrated this code that way (like proposed here http://gis.stackexchange.com/questions/52983/syntax-for-arcgis-icalculator-object/198681#198681 )  :
  (B)
  Dim nCentroidXFieldIndex As Integer = pFeatureClass.FindField("centroidX")
  Dim nCentroidYFieldIndex As Integer = pFeatureClass.FindField("centroidY")
  Dim nBldg_sizeFieldIndex As Integer = pFeatureClass.FindField("Bldg_size")
      If TypeOf pFeatureClass Is IFeatureClass Then
  If TypeOf pFeatureCursor Is IFeatureCursor Then
  Dim pArea As IArea
  Dim pFeature As IFeature = pFeatureCursor.NextFeature()
  Dim myProgressCalc As New FileProgressForm
myProgressCalc.set_maximum(iTotalRecords)
myProgressCalc.Show()
myProgressCalc.Text = "Veuillez patienter svp"
myProgressCalc.lblProgress.Text = "Calcul des données géographiques"
myProgressCalc.Update()
   pArea = CType(pFeature.Shape, IArea)
   While pFeature IsNot Nothing
pFeature.Value(nCentroidXFieldIndex) = pArea.Centroid.X
pFeature.Value(nCentroidYFieldIndex) = pArea.Centroid.Y
pFeature.Value(nBldg_sizeFieldIndex) = pArea.Area
   pFeature.Store()
pFeature = pFeatureCursor.NextFeature
   myProgressCalc.Go()
    End While
myProgressCalc.Close()
  End If
  End If
  It’s working but it’s working extremely slowly ! The first code (A) was executed in less than 3 minutes. The new one (B) in 25 minutes !
  In fact, I just want to programmaticaly call a the new calculate geometry tool (when displaying attributes table - http://desktop.arcgis.com/fr/arcmap/10.3/manage-data/tables/calculating-area-length-and-other-geometric-properties.htm )
Screen capture 1
Too bad, can't upload PNG and JPEG files...
or Arc tool => Data Management Tools => Entities => Add geometric attributes (http://pro.arcgis.com/fr/pro-app/tool-reference/data-management/add-geometry-attributes.htm )
  Screen capture 2
or any other methods !
Both tools are working great in ArcGis Desktop but I can’t find my way to make them work in VB.NET.
Please, any suggestions ? (It’s just driving me crazy).
Thanks by advance for your answer, and sorry for screen capture in french and for poor english speaking
  Matthieu
Outcomes
