Intersect and x,y co-ordinate generation
2145
06-16-2016 03:22 AM
StevePace1
I have several polylines which intersect.  I need to find the X,Y co-ordinates of the intersection points.  The intersect tool, run several times for each polyline pair has correctly identified the points, but has grouped them according to feature class.  I therefore have, instead of the expected 50 or so points, just 20 points in my attribute table of the merged results of Intersect.  How can I get the individual points to show in the attribute table (and then I can run "calculate geometry")?
I am using a Basic licence of ArcMap 10.3, with a network licence for Spatial analyst if needed.
Thanks in advance for any help!
JayantaPoddar
MVP Esteemed Contributor
Post-intersection, you can use Multipart To Singlepart—Help | ArcGIS for Desktop to generate individual records for each point. Then you can calculate X/Y coordinates using Calculate Geometry.
Think Location
JayantaPoddar
Think Location
StevePace1
This worked perfectly - thank you!
