Widget LayerList Dijit
839
06-15-2016 08:34 AM
GokuSan
I have a problem with the layerlist widget. I created a project where two layers are loaded, I build the widget and everything goes properly. The code would be:
<!DOCTYPE html>
<html>
<head>
<title>Layer List Dijit</title>
<link rel="stylesheet" href="https://js.arcgis.com/3.16/dijit/themes/claro/claro.css">
<link rel="stylesheet" href="https://js.arcgis.com/3.16/esri/css/esri.css">
<style>
html, body, .container, #map {
    height:100%;
    width:100%;
    margin:0;
    padding:0;
    margin:0;
    font-family: "Open Sans";
#map {
    padding:0;
#layerListPane{
    width:25%;
.esriLayer{
  background-color: #fff;
.esriLayerList .esriList{
    border-top:none;
.esriLayerList .esriTitle {
  border-bottom:none;
.esriLayerList .esriList ul{
</style>
    <script>var dojoConfig = { parseOnLoad: true };</script>
  <script src="https://js.arcgis.com/3.16/"></script>
    <script>
      require(["esri/map",
    "esri/layers/ArcGISDynamicMapServiceLayer",
    "esri/dijit/LayerList",
    "dojo/domReady!"], function(Map, ArcGISDynamicMapServiceLayer, LayerList) {
        var map = new Map("map", {
          //basemap: "topo",  //For full list of pre-defined basemaps, navigate to http://arcg.is/1JVo6Wd
          center: [-122.45, 37.75], // longitude, latitude
          zoom: 13
  var demographicsLayerURL = "https://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer";
  var demographicsLayerOptions = {
  "id": "demographicsLayer",
  "opacity": 0.8,
  "showAttribution": false
  var demographicsLayer = new ArcGISDynamicMapServiceLayer(demographicsLayerURL, demographicsLayerOptions);
  map.addLayer(demographicsLayer);
   var oilAndGasLayer = new ArcGISDynamicMapServiceLayer("https://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Petroleum/KGS_OilGasFields_Kansas/MapSer...", {
  "id": "oilAndGasLayer",
  "opacity": 0.75
  map.addLayer(oilAndGasLayer);
     var myWidget = new LayerList({
           map: map,
           //layers: arcgisUtils.getLayerList(response)
           showLegend: true
        },"layerList");
        myWidget.startup();
    </script>
  </head>
  <body class="claro">
  <div class="container" data-dojo-type="dijit/layout/BorderContainer"
  data-dojo-props="design:'headline',gutters:false">
  <div id="layerListPane" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'right'">
  <div id="layerList"></div>
  </div>
  <div id="map" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center'"></div>
  </div>
  </body>
</html>
However , when I do another test the widget does not work properly. I mean, my goal is to add a single layer in the domready and when I click on the map, a second layer is added and the widget is updated. The code is:
<script>
    "dojo/on",
    "dojo/domReady!"], function(Map, ArcGISDynamicMapServiceLayer, LayerList, on) {
          zoom: 13
  "opacity": 0.8,
           map: map,
           removeUnderscores: true,
    showLegend: true
        },"layerList");
        myWidget.startup();
  map.on("click", function(evt){
  "opacity": 0.75
  oilAndGasLayer.on("load", function () {
  var layers = new Array();
  for (var j = 0; j < map.layerIds.length; j++) {
  layers.push(map.getLayer(map.layerIds));
  myWidget.layers = layers;
  myWidget.map = map;
  myWidget.refresh();
    </script>
Can anybody help me? Thank you very much in advance
