ArcGIS Server - problem publishing python script that uses urllib
2576
06-14-2016 12:02 PM
MaxDemars
New Contributor III
Hi!
I have problem publishing a simple python script as geoprocessing service with ArcGIS Server.
import urllib
import arcpy
u = arcpy.GetParameter(0)
url = "http://geoegl.msp.gouv.qc.ca/cgi-wms/mapcache.fcgi/tms/1.0.0/carte_gouv_qc_public@EPSG_3857/" + u
image = urllib.urlopen(url).read()
arcpy.SetParameter(1,image)
This is a simple proxy that uses urllib to redirect images. When I try to publish this script, ArcMap always go idle and finally crash. If I try to publish a script that do not import urllib, I have no problem.
Can someone tell me if trying to publish a python script that import urllib into ArcGIS Server could make the Publisher crashing?
MaxDemars
New Contributor III
After letting the publisher running idle for a while some errors shows up:
High    Unresolved    00178    Data: C:\Windows\bfsvc.exe, used by Script Script cannot be copied to the server
High    Unresolved    24032    Data source used by Script Script is not registered with the server and will be copied to the server: C:\temp\arcgis\arcpy\
Any idea what is going wrong?
AnthonyPopp
Have you looked at the following post:
geoprocessing service analysis/publish errors, trying to copy "data" that isn't needed
It looks like if you change your import from:
import urllib
to:
from urllib import *
this may resolve your problem.
