Slope, elevation and area calculation in DEM
5326
06-11-2016 02:05 PM
ElzaMartinez
Hi guys,
I have an assignment to hand in at uni and I have come to a point where I don't know which method to use to complete it and I receive no guidance from my tutors. As I am new to GIS I can't make heads from tails so I would immensely appreciate your help.
Here goes:
I have a DEM of the German alpine area as well as several vector files pertaining to land use, streets, railways etc. I need to determine which areas can count as "alps" based on the criteria elevation (between 600 and 800 m NN), percentage rise of the slope (above 18%) and at least 5 hectares big. I get the general idea that I first have to calculate or classify these numbers and then find a way (perhaps by converting into a vector file?) of excluding everything that doesn't fulfill these. I have looked around arcGIS, have watched several videos and even looked at the slope and reclassify tool, but I feel very uncertain as to whether I am doing the right thing. When it comes to finding out a certain elevation, the tool that seems most plausible to me is reclassify, whereby it looks as though you can manipulate the data. Should I just do that? Should I just create new elevation classes according to my needs? Would that not mess with the underlying data?
As you see, I really need a guiding hand.
Thanks for your help!
Elza
MikeCusi
Occasional Contributor II
1. Use the CON tool so that only those elevation that fits your criteria will be included in the output. = map1
2. using map1, use the SLOPE tool. = map2
3. using map2, use the CON tool again to select only those that are > 18%. = map3
4. convert map3 to a polygon (RASTER to POLYGON Tool) and select only those that are >= 5 ha.
